Different ramp rates
Can I have a different ramp rate in the node (closet light) versus the that same light in a scene (that light is the only thing in that scene) when these are part of program?
Hi. Yes, both are set in the admin console.
  • For the device locally or direct device commands: You click on the device in the admin console to set its local behavior if its a dimmer, the percentage on and the ramp rate.
  • For each scene: Click on the scene name in the list in the admin console. The list of devices appears, and for dimmers you can individually set the percentage on and the ramp rate. When you turn that scene on and off, those specific settings will be used
Paul
Edited by paulbates
