ApplianceLinc Is Blue In Device Tree And Does Not Appear In MobiLinc
An Insteon ApplicanceLinc is blue in the device tree of my ISY99i IR Pro. It is used in a program nested in a folder and turns a light on and off at specified times. It performs the task as programmed and it may be turned on and off at the device tree level in the admin control panel. However, it does not appear in the list of devices in MobiLinc. It only appears there as part of the nested program. Does anyone know here know why or should I address my question to MobiLinc?
It's blue in the device tree because of the device type. Responder-only devices, like the ApplianceLinc or the older LampLinc, appear in blue, while devices that can act as Controllers (like the On/Off Module, the newer LampLincs with bright/dim buttons on the side, SwitchLincs, etc.) show in that reddish hue.
You can intentionally hide and un-hide devices in MobiLinc. Go to Settings, Lighting Controller, Hidden Items to see the list.
Thanks for the feedback. I don't know how a newly linked device found its way into the hidden devices on MobiLinc but it did. Problem solved.
