Mobilinc + isy994i scene = crash
So..  I have a scene with one of the buttons of an 8 button keypad as controller, and an outdoorlinc as responder...
All works fine at the keypadlinc button.
If I login to the java console and hit on (at the scene), only the 8 button keypad turns on, the outdoorlinc doesn't.  If I hit fast on however, they both turn on as expected... off works as expected.  not sure why...
Now this is where gets odder.... I use mobilinc, and if I try to turn the scene on, I get the message
"Bad Message
ISY failed to process the request.
Please try again"
If I use mobilinc and try fast on at the scene, the ISY994i crashes and auto-restarts...
I'm not sure if this is a bug in the ISY or mobilinc, or if something different is going on?
