New Thermostat - Wiring Help Needed
Hi,
I just bought a 2441TH thermostat to replace my Honeywell one.  However, after wiring it up I got hot air instead of cool for the cool setting.  I also got hot air from the heat setting.  So, my assumption is I wired something wrong.  I know it is not my A/C unit since I hooked the Honeywell back up and everything works.
Here is the wiring for the Honeywell
Here is what I did with the wiring....
Right Side of Honeywell                     2441TH
Red Wire                                          24RH
Orange                                             W2  (1st attempt I had this connected to W1, then when I connected the white wire I moved it to W2 - same result)
Yellow                                               Y1
Green                                                G
Blue                                                 24V COM
Left side of Honeywell                   2411TH
Top White wire                                W1 (I didn't connect this on the 1st attempt, then connected it and still same result)
Red                                                  Not connected
White                                               Not connected
I think the bottom white and red wires on the left side are for the outside temp reading since they are a separate wire run.
Any suggestions on the wiring....?
Edited by Grayson
I don't have a pic for the Insteon one since I removed it put the the Honeywell back.  I tried to show the wiring above.
Is the below clearer?
Right Side of Honeywell               Connected to 2441TH
Red Wire   ---------------------->          24RH
Orange      ---------------------->          W2  (1st attempt I had this connected to W1, then when I connected the white wire I moved it to W2 - same result)
Yellow         --------------------->          Y1
Green         --------------------->          G
Blue            ---------------------->         24V COM
Top White wire  ----------------------> W1 (I didn't connect this on the 1st attempt, then connected it and still same result)
Red                                                  Not connected
White                                               Not connected
Not sure what you mean by gas 2 stage heater?  How would I determine that?
You should also take a look at the furnace to see what terminals the wires are connected to
Is your  air conditioning a single stage or two stage compressor?
Does the furnace have a two stage gas valve?
Do you have an external temperature sensor that was connected to the Honeywell?
Edited by Techman
The 2441TH is not compatible with a heat pump.
Arghh......I think I have a heat pump system. Any there any solutions for the ISY that work with a heat pump system?
There are Insteon compatible Venstar thetmostats, actually Insteon adapters for some Venstar thermostats. They're available at the SH store. I have two, no longer in use, if you're interested.
Edit: T1800 + adapter
Edited by stusviews
  • 1 year later...
The Venstar T7800-7900 series have heat pump modes to provide switch over contacts.
They can be interfaced via RPi using NodeLink .
