How to turn off ceiling fan after no motion detected after 1 hour?
I'm trying to write a simple program that will turn off my ceiling fan if no motion from my Insteon motion dectector has been detected for over an hour. Any ideas on how best to accomplish this?
Thank you...
Edited by ahwman
Each time Motion Sensor senses motion the Wait starts over, waiting for 1 hour.  When no motion for 1 hour wait completes and Fan is turned Off.
If Control 'Motion Sensor - Sensor' is switched On
   Wait 1 hour
   Set 'FanLinc - Fan' Off
        control motion sensor is turned on
        wait 1 hour
        set fan off
Each time motion is sensed the program runs, thus restarting the wait period .
   Wait 1 hour
This is provided that you have a "direct link" between your MS and your fan tha you can install by creating a scene in ISY. If not you will require an extra line of code to turn the fan on.
   Set 'FanLinc - Fan' On
   Wait 1 hour
There is no dependency on a "direct link" for this example to work.  The OP did not discuss how he should turn the Fan On.  Fan could be a member of a Scene, could be the Responder to a Controller Only device such as RemoteLinc2 (Mini Remote), etc.  Hopefully the OP will post back if there is a question on turning Fan On.  Certainly worthy noting though.
I was able to get it working thanks to your help. This is a great community!
