KPL with one button for on/bright, another button as off/dim
This is for an 8 button KPL.
I would like to define button G to be On and brighten when held down.
I would like to define button H to be Off and dim when held down.
I set button G and H to each be non-toggle.
I put button G in a scene with the desk light. I clicked the red button under the scene name and set the on level of the light (listed on the lower half) to 30% and set a ramp rate.
I put button H in a different scene with the desk light. I clicked on the red button G in the scene and set the light level to 0%.
Button G works. Press and release and it goes to 30% as set in the scene. Press and hold, and it will brighten. (Locally the light goes to 60%, so I know the scene is controlling the level.)
I cannot get button H to dim. It will only turn the light off, it will not dim.
What am I doing wrong?
The 6 button KPL comes with this ability out of the box, can we not make other buttons behave the same way?
The 6 button KPL comes with this ability out of the box, can we not make other button behave the same way?
Edited by nowandthen
I assume H is set to non-toggle Off mode so it is not illuminated.
In non-toggle Off mode the button generates an off command when pressed.
It shows "Non-Toggle [On]" and it is not illuminated. I figured I would deal with illumination later.
Got it!
I set button H to Non-Toggle [Off] mode, I didn't realize what it was asking when I went to set it to non-toggle mode.
So with the button in Non-Toggle [Off] mode, I also had to change the lamp level to 100% (previously I had it at 0% and even in Non-toggle[Off] it would not dim.)
Works great!
Thanks Lee! You are amazing!
