Remote access stopped working?
Hi,
I use a saved web page favorite to login to ISY & a DDNS to keep track of the system.
The other day it stopped working.  I also use subsonic & port forwarding - same as my ISY.
Now it wont work.  If i type My.ip.com:4034 it used to work & now doesnt work.
My subsonic is set to 4035 & works fine.  If I change my port forwarding rules so the ISY has 4035, it doesnt work.  If I swap back it does.  If I put subsonic on 4034 it works fine.
What may be the problem?  The subsonic & ISY are on the same switch.
It worked fine & now doesnt.
Any suggestions would be welcome.  I need the ISY functionality on my phone remotely (to go with my cameras which also work via port forwarding).
Using ISY 4.2.8
Rich
Edited by RichTJ99
Each device you want to access off-site must have a unique port. Port sharing is generally not allowed.
This sounds contradictory. Does port 4034 work for ISY or not?
Are also changing ISY's port inside ISY, to match,  or are you just changing the Port Forwarding rules, external side of the router?
