Programming options for Insteon Thermostat?
I'm looking at possibly purchasing the 2441TH SmartHome Insteon Thermostat... but wondered what kind of programming options the ISY has available for it?  Does anyone have a screen capture?  For example, could I have a RemoteLinc and press Bright to bump the temp up a degree, or tap dim 3 times to drop the temp 3 degrees?
The buttons referred to are defined as follows:
Button 1 ON: call for heat (Zone 2)
Button 1 OFF: Turn off Zone 2
Button 3 ON: call for cool (Zone 2)
Button 3 OFF: Turn off Zone 1
Set setpoint down 1º by pressing DIM on the RemoteLinc
BR Cooler - [iD 0081][Parent 0076]
        Control 'BR / Devices / BRR HVAC1 Heat-Zone 2 Off' is switched Dim  (last button pressed called for heat)
     Or Control 'BR / Devices / BRR HVAC1 Heat-Zone 2 Off / BRR HVAC3 Cool-Zone 1 Off' is switched Dim (last button pressed called for cool)
        Set 'BR / Devices / BR Thermostat Main' Setpoint Down 1°
Set setpoint up 1º by pressing BRIGHT on the RemoteLinc
BR Warmer - [iD 0082][Parent 0076]
        Control 'BR / Devices / BRR HVAC1 Heat-Zone 2 Off' is switched Bright (last button pressed called for heat)
     Or Control 'BR / Devices / BRR HVAC1 Heat-Zone 2 Off / BRR HVAC3 Cool-Zone 1 Off' is switched Bright (last button pressed called for cool)
        Set 'BR / Devices / BR Thermostat Main' Setpoint Up 1°
Edit: You must use the DIM and BRIGHT buttons on the RemoteLinc, Holding the top (brighten) or bottom (dim) of the control buttons doesn't work.
Edited by stusviews
There's a few seconds delay between the press and the response.
This (Setpoint Up 1°) has never worked with my two different versions of the 2441ZTH (note 'Z') with ISY.
I haven't tested this with the newer releases 4.3.1 ++.
