Program Problem
I want the BuzzLinc to buzz 3 times when either of 3 hidden door sensors are open between sunset and sunrise the next day. The buzzer sounds whenever a door is opened, i.e., it is unrestricted as to the timeframe. What am I doing wrong?
        From    Sunset
        To      Sunrise (next day)
    And Status  'Door Sensors / Deck Door Sensor' is On
     Or Status  'Door Sensors / Kitchen Door Sensor' is On
     Or Status  'Door Sensors / Man Cave Door Sensor' is On
        Repeat 3 times
           Set 'BuzzLinc' On
           Set 'BuzzLinc' 2 (Beep Duration)
           Set 'BuzzLinc' Off
        Set 'BuzzLinc' Off
Need Parens so time range applies to all Sensors
        From    Sunset
    And
        Repeat 3 times
           Set 'BuzzLinc' On
           Set 'BuzzLinc' Off
        Set 'BuzzLinc' Off
What, specifically, is not working correctly? Which mode is the I/O Linc set for, Latching, Momentary A, B, C?
Also if the BuzzLinc should alert ONLY when door is Opened and NOT if door remains Open then use If Control
        From    Sunset
    And
          Control  'Door Sensors / Deck Door Sensor' is switched On
     Or  Control  'Door Sensors / Kitchen Door Sensor' is switched On
     Or  Control  'Door Sensors / Man Cave Door Sensor' is switched On
        Repeat 3 times
           Set 'BuzzLinc' On
           Set 'BuzzLinc' Off
        Set 'BuzzLinc' Off
Thanks. Once again I am educated by the experts. I didn't know that parenthses served that purpose.
Generally Parens are needed when the If has both Or and And statements.  The Parens bracket a set of conditions, a group of Ors or a Group of Ands that then need to be Ored or Anded with something else.  Without the Parens some of the Ored conditions operate without benefit of the time range.  The Wiki has some examples that may be helpful.
