Run fan for 30 seconds every 10 minutes
How can I program a fan to be run for 30 seconds every 10 minutes?
I am lost don't know where to begin with this one ...
THanks!
Need to know what starts the process.   If always, set Program to Run at Startup.  If by some device action, such as pressing a KPL button or similar, just need to know what that is.
The meat of the Program
  depends on additional information
   Repeat every 10 minutes
       Set 'fan' On
       Wait 30 seconds
       Set 'fan Off
   Set 'fan' Off
Edited by LeeG
       Set 'fan' On
       Wait 30 seconds
       Set 'fan Off
   Set 'fan' Off
Thanks! I will use a variable to get the program running.
Only state variables will trigger programs when they change value. Integer types do not trigger programs but can be used for testable status in logic statements.
ISY has an event based engine. You don't usually poll devices with software.
