Socket open failed javax.net .......
I can't get into my console anymore from another location.  What is going on this time?  It says Socket open failed javax.net.ssl.SSLHandshakeException: server chose SSLv3 but protocol version is not enabled or supported by the client.  Then it goes to error.  XML Parse error https and my ip
What can I do?  Thanks.
The Admin Console no longer supports SSL because of the security issues with SSL.  What ISY level and UI level is being used (Help | About).
From 4.3.10 announcement, but I believe even 3.2.30 indicated SSL3 no longer supported.
IMPORTANT SSLv3 is now disabled. All models now support TLS1.2 and high grade cipher suites
Sure.  The 4.3.10 image supports TLS1.2 and high grade cipher suites.  From the 4.3.10 announcement ....
