Motion sensor on front porch
I have a new motion sensor on the front porch connected to the light. It is set to occupancy mode and On only.
What I want is if all of us are away, and the motion sensor is tripped, I want a notifcation every minute.
I have everything except for the alert working like I want. How do I get it to alert me on the first trip and the wait a minute and then alert me again if there is still motion?
Program 1
        Control 'Motion Sensor' is switched On
        Send Notification to 'me'
        Run Program 'Program 2' (Then Path)
Program 2
        Disable Program 'Program 1'
        Wait  1 minute
        Enable Program 'Program 1'
Duh, I tried doing exactly like that but all within the same program. I don't remember why it didn't work. What prevents this from being all one program. If a program command disables the program itself, does the program continue to run?
If a program is disabled, then it ceases to run until such time as another program enables if or if it's manually enabled.
So if a program disables itself and is still executing the then loop it can't later in the same then loop re-enable itself?
The program is disabled as soon as the disabling statement is executed.
The program is halted and disabled.
