Schlage Tamper setting at Night and Forced Entry during the day
Is there a way to set Schlage Keypad locks to Tamper after sunset till sunrise and than set it back to Forced Entry with ISY994? Thank You for any help?
Nope. The only program options allow you to check the state of the lock or to lock or unlock the lock.
It MAY be possible actually.  I believe the ZWave options for the locksets can be accessed via the /Rest interface.  If you have the network module, you may be able to have the ISY call itself via the rest interface to set the necessary options.  I resource for each setting and call those from programs.
-Xathros
I am curious as to the use case and how this is applied in a real world application? Can you provide some more clarity and insight as to your overall use case and intent for the benefit of the forum members?
Being a user of the Schlage locks myself, I can see where I would want to reduce the sensitivity of the alarm during the day when the kids and dogs are bumping around and triggering the alarm by accident but go back to high sensitivity at night when the house is calm.
-Xathros
-Xathros
Is this *tamper* feature active when the lock set is not in the locked position?
No, however my locks spend most of their time in the locked position even during the daytime.
-Xathros
