Elk Module issue...
In the admin console I used to have an Elk tab and Elk buttons above the tab like "Arm" Disarm", etc.  The tab is there but not the buttons.  How do I get them back?
Can the ISY talk to your Elk or is it possible they have lost their connection?
Does the ISY show your Elk zones correctly?
Dennis
I'm thinking the connection has been lost.  The ISY doesn't show any zones.
That is what I suspected. You will need to establish a connection and then everything will restore. Has anything changed on the configuration page of the ISY? Make sure all of the information is correct and make note of the port number. You will then need to connect with your ELk via the software and verify the settings there.
Dennid
