Motion Sensor Option setting
tmorse305
I just purchased an ISY994i IR PRO to replace a Cortexa (and some HouseLinc) automation controller.  So I'm new to ISY but not home automation.  I have a new motion sensor that I bought and have linked it to the ISY, it's the only device linked.  I factory reset the sensor prior to linking and it is working correctly reporting both motion, dawn/dusk and battery(off) to the ISY.  The problem comes when I try to modify the option settings.  I set the led flashing on the MS then click the options button and I get an error message "Request Failed".  Once the Option screen is open I click the query button but get the same error message.  I linked it to my Houselinc software just to make sure the MS is working.  From the Houselinc I was able to set to the options.  So I think the MS is OK. Any suggestions?  Thank you.
Sounds like you do not have many (or any) dual-band devices. The MS is RF only. Try bringing it closer the the serial PLM. BTW, what are you using to interface between HouseLinc and the powerline.
The only dual band device currently connected to the ISY is the PLM itself.  The MS is about 6ft away from the PLM.  Since I can read the motion, dawn/dusk and battery status I figure i was close enough. The HouseLinc is also connect via a USB PLM.  I have many dual band devices in my house but I haven't linked any of them to the ISY yet.  I was starting small just to get the feel of the ISY.
Run Tools | Diagnostics | Event Viewer at LEVEL 3.    Put MS into linking mode and click Options.  Update a setting such as Timeout.  When System Busy in lower left corner is no longer displayed, copy event trace to clipboard (icon at bottom right next to last of event viewer viewer window).  Post to forum.
Edited by LeeG
Is jumper #5 on the MS installed to allow remote software management?
Jumper #5 is set for software control.  Here is the Event Viewer dump:
Sat 09/12/2015 08:33:02 PM : [All         ] Writing 0 bytes to devices
This single entry occurred after I tried to update an option
What does Tools | Diagnostics | PLM Info/Status show.    The trace provides no information as it looks like the ISY may be having an issue with the PLM.
Also what does Help | About show for Firmware and UI levels.
Edited by LeeG
Did you put the MS into linking mode before you tried the write?
All battery operated devices go into sleep mode to prolong battery. The set button must be pressed for about 4 seconds to put the device into linking mode in order to do a write
Edited by Techman
Here is the log file for a motion off then motion on:
Sat 09/12/2015 09:47:35 PM : [iNST-SRX    ] 02 50 37.A4.56 00.00.01 CF 13 01    LTOFFRR(01)
Sat 09/12/2015 09:47:35 PM : [std-Group   ] 37.A4.56-->Group=1, Max Hops=3, Hops Left=3
Sat 09/12/2015 09:47:35 PM : [  37 A4 56 1]      DOF   1
Sat 09/12/2015 09:47:35 PM : [  37 A4 56 1]       ST   0
Sat 09/12/2015 09:47:36 PM : [iNST-SRX    ] 02 50 37.A4.56 00.00.01 CF 13 01    LTOFFRR(01)
Sat 09/12/2015 09:47:36 PM : [std-Group   ] 37.A4.56-->Group=1, Max Hops=3, Hops Left=3
Sat 09/12/2015 09:47:36 PM : [iNST-DUP    ] Previous message ignored.
Sat 09/12/2015 09:47:36 PM : [iNST-SRX    ] 02 50 37.A4.56 13.00.01 CF 06 00           (00)
Sat 09/12/2015 09:47:36 PM : [std-Group   ] 37.A4.56-->13.00.01, Max Hops=3, Hops Left=3
Sat 09/12/2015 09:47:36 PM : [iNST-INFO   ] Previous message ignored.
Sat 09/12/2015 09:48:50 PM : [iNST-SRX    ] 02 50 37.A4.56 00.00.01 CF 11 01    LTONRR (01)
Sat 09/12/2015 09:48:50 PM : [std-Group   ] 37.A4.56-->Group=1, Max Hops=3, Hops Left=3
Sat 09/12/2015 09:48:50 PM : [  37 A4 56 1]      DON   1
Sat 09/12/2015 09:48:50 PM : [  37 A4 56 1]       ST 255
Sat 09/12/2015 09:48:50 PM : [iNST-DUP    ] Previous message ignored.
Sat 09/12/2015 09:48:50 PM : [iNST-SRX    ] 02 50 37.A4.56 11.00.01 CF 06 00           (00)
Sat 09/12/2015 09:48:50 PM : [std-Group   ] 37.A4.56-->11.00.01, Max Hops=3, Hops Left=3
Sat 09/12/2015 09:48:50 PM : [iNST-INFO   ] Previous message ignored.
Sat 09/12/2015 09:48:51 PM : [iNST-SRX    ] 02 50 37.A4.56 11.00.01 CF 06 00           (00)
Sat 09/12/2015 09:48:51 PM : [std-Group   ] 37.A4.56-->11.00.01, Max Hops=3, Hops Left=3
Sat 09/12/2015 09:48:51 PM : [iNST-INFO   ] Previous message ignored.
Edited by tmorse305
The MS was in linking mode prior to the write attempt.  Here are the screen shots you requested.
You either need to upgrade your FW or downgrade your UI.. they need to be the same..
      37.8k
      378.1k
