Clear a Stuck Program
I have a program in my controller that is no longer relevant.  I tried to delete it, but it keeps executing.  I removed all devices and scenes related to the program, re-added them and re-configured everything, but the program continues to execute.  I've rebooted the controller, and the program still executes.
In case it's relevant, I had a set of pool lights that, when you turned them on, if you turned them off and back on again, they would change colors.  So, I programmed them such that when I turned on my pool light key pad button, it turned the lights on, waited, turned them off, waited and turned them back on.  I have since replaced the lights.  The new lights don't require these actions to create a light show.  But, despite having taken the actions above, when I turn the lights on, they turn off and back on again.
Can anyone help?
When you delete the program, does it disappear from the list of programs along the left side? When you later log in has the program returned? When you delete the program, do you "save changes"?
  • Yes, when I deleted the program, it disappeared from the left side.
  • Yes, having just logged back on (first time in ~20 hours), I can confirm that the program is still gone from the left hand side.  I can also confirm that the program still appears to be running (i.e. when I turn the lights on, they turn on, wait, turn off, wait and turn on).
  • I don't recall if I saved the changes after deleting the program.  I just did it now, but the behavior is unchanged.
Any other thoughts?  Thanks.
Select the errant device. At the extreme right is a panel Labelled Membership. Is the device a Controller of or Responder to any scenes?
By errant device, do you mean the inline switch wired into the pool lights or the keypad?  I assume the former, but just checking.  I'll check in tonight when I can have a look.
