Enable Integration
gregseigs1
What are you assuming is for remote access and where are you finding this option?
For no-ip you need an account with the service and you need a no-ip client running on a 24x7 PC or a router that supports this. Somebody has to send your IP address on a timed basis to no-ip so they know what IP you have been issued by your ISP.
No-IP will issue you a URL like this.  www.gregseigs1.noip.com that you will use that will echo your data to your router.
If I am in the Ekeypad app (I am using an iPhone), under the config tab, then under advanced settings, there is a button for "Enable Integration".
When checked, I entered my ddns address, 2601 for the port, my server name and password.
Will not work after that.  What am I doing wrong here?
Sorry. I am not an iStuff person.
  • 1 month later...
I'm having the same problem. I've tried port number 86 which I select on my ISY, port number 443 and port number 2601. I get the message The remote management server can not be contacted. I'm not new to this but can't get this feature to work.
      37.5k
      375k
