Simple programming question
rick.curl
I've got a bunch of programs and they're all running fine, but I'm trying to add one that should be simple but I can't get it to work.
Here's what I'm trying to do: On Mondays I leave the house at 5:30 AM, and on Tuesday, Wednesday, and Thursday I leave at 6:00.  If it's dark when I leave I would like the side yard light to be on for 15 minutes.  Here's what I've got at the moment:
   From    Sunset
   To      Sunrise (next day)
   And     On Tue, Wed, Thu
           Time is 6:00:00AM
   Or      On Mon
           Time is 5:30:00AM
     In Scene 'Outside / Side Yard'  Set 'Outside / Side Yard' 100% (on Level)
     Wait 15 minutes
     In Scene 'Outside / Side Yard'  Set 'Outside / Side Yard' 0% (on Level)
   -No actions
I tried changing "Sunrise" to "same day" but it is still never running.  This has got to be something ridiculously simple that I'm overlooking.  What is it?
-Rick
There's no need for the Sunset-Sunrise condition.
I assume you are using the sunrise and sunset conditions as "dark", correct?
I suspect you have some logical priority issues here.  This can be corrected with a couple of parenthesis.  I also suspect your THEN clause is incorrect.  Rather than setting the responder levels, simply turn the scene on.
   From    Sunset
   And
On Tue, Wed, Thu
           Time is 6:00:00AM
   Or   On Mon
           Time is 5:30:00AM
     Set scene 'Outside / Side Yard'  ON
     Wait 15 minutes
Set Scene 'Outside / Side Yard'  OFF
   -No actions
Try this. The parenthesis supercedes the AND which has a higher priority than the OR.
It should have worked on Mon at 5:30 regardless
   From    Sunset
   And  (
           On Tue, Wed, Thu
           Time is 6:00:00AM
   Or      On Mon
           Time is 5:30:00AM
     In Scene 'Outside / Side Yard'  Set 'Outside / Side Yard' 100% (on Level)  <--- set scene ON not modify it
     Wait 15 minutes
     In Scene 'Outside / Side Yard'  Set 'Outside / Side Yard' 0% (on Level)    <---set scene Off, not modify it
   -No actions
EDIT: OberKC is correct.I missed the then problem. Modifying scenes does not activate them.
oberck is correct. The scene should be set to On of Off.
I didn't know about parenthesis.  I'll read up on it.
I modified my program as suggested in post#4 above.  I'll report back when I find out if it works tomorrow morning.
Appreciate the help!
-Rick
      378.4k
