Restore PLM question with Morning Ind. door lock
The restore went well, I even got a door sensor working by put it in linking mode (hold set button for several seconds) and then Updating devices in Admin Console.   What I can't do is get the lock into linking mode.  I do have a  Morninglinc, so should I be holding the set button on the Morninglinc.   This probably makes sense because I believe ISY is only able to see the Insteon module, not the lock itself.  Just don't want to make any mistakes.
The door lock is still fully functional so I'm hoping nothing too drastic is required.
Edited by satwar
That's true. The lock is not an Insteon device, the Morninglinc is. The Morninglinc communicates with the lock via Insteon commands.
Well I'm stuck unfortunately.  The Morninglinc still talks with the lock when I push the set button, which is good.  I removed the Morninglinc device from  ISY, but I can't add the device back in because ISY can't determine the Insteon engine.  I'm using the older 2458A1 Morninglinc.
Were these steps from Wiki followed?  Step 1 has already been done
  1. Manually link the MorningLinc to the Locks(s)
  2. See Link Management Menu to tell the ISY to Start Linking.
  3. Select the third option 'Add devices found in links and keep existing links'.
    • If you select 'Remove existing links' it removes all links from the MorningLinc and due to the security measures on the MorningLinc the PLM can no longer send commands to it.
  4. Link the MorningLinc to the ISY by pressing the Set button on the MorningLinc for 3-5 seconds.
    • If the MorningLinc does not appear on the ISY console press the set button once again and press and hold again.
  5. Click on the Finish button on the Linking in Progress dialogue requester.
  6. Some dialogue will take place between the ISY and the MorningLinc to create the links necessary to view and control the device state.
  7. The MorningLinc should now be available as a device in the Console and in Programs.
I successfully Deleted a MorningLinc v.3A under 4.3.26, added it back following Wiki instructions, and can LOCK/UNLOCK lockset using MorningLinc.
Wed 10/21/2015 01:24:19 AM : Start Insteon Device Linking Mode
Wed 10/21/2015 01:24:19 AM : [LNK-BGN     ] 02 64 01 00 06
Wed 10/21/2015 01:24:43 AM : [LNK-STAT    ] 02 53 M(01) gid=00 18.EE.8F 0F06 3A
Wed 10/21/2015 01:24:43 AM : [18.EE.8F 00] Linked device type=0F.06 fw=3A
Wed 10/21/2015 01:24:43 AM : [18 EE 8F 0  ] Added to list of devices to link to ISY
Wed 10/21/2015 01:24:43 AM : [LNK-BGN     ] 02 64 01 00 06
Wed 10/21/2015 01:24:50 AM : Stop Insteon Device Linking Mode, Final processing to follow
Wed 10/21/2015 01:24:50 AM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Wed 10/21/2015 01:24:50 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 0D 00
Wed 10/21/2015 01:24:51 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 0D 00 06                 (00)
Wed 10/21/2015 01:24:51 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 0D 01           (01)
Wed 10/21/2015 01:24:51 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:24:51 AM : [18 EE 8F 0  ] Calibrating engine version
Wed 10/21/2015 01:24:51 AM : [18 EE 8F 0  ] May not fully support i2, reverting to i1
Wed 10/21/2015 01:24:51 AM : [18 EE 8F 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Wed 10/21/2015 01:24:51 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:24:51 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:24:52 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:24:52 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:24:52 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F8
Wed 10/21/2015 01:24:52 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F8 06          PEEK   (F8)
Wed 10/21/2015 01:24:52 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B A2    PEEK   (A2)
Wed 10/21/2015 01:24:52 AM : [18 EE 8F 0  ] MorningLinc database accessible
Wed 10/21/2015 01:24:52 AM : [18 EE 8F 0  ] Reading all links
Wed 10/21/2015 01:24:52 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:24:52 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:24:53 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:24:53 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:24:53 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F8
Wed 10/21/2015 01:24:53 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F8 06          PEEK   (F8)
Wed 10/21/2015 01:24:53 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B A2    PEEK   (A2)
Wed 10/21/2015 01:24:53 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:24:53 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:24:54 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:24:54 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:24:54 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F9
Wed 10/21/2015 01:24:54 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F9 06          PEEK   (F9)
Wed 10/21/2015 01:24:54 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:24:54 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:24:54 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:24:55 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:24:55 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:24:55 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FA
Wed 10/21/2015 01:24:55 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FA 06          PEEK   (FA)
Wed 10/21/2015 01:24:55 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 22    PEEK   (22)
Wed 10/21/2015 01:24:55 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:24:55 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:24:56 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:24:56 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:24:56 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FB
Wed 10/21/2015 01:24:56 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FB 06          PEEK   (FB)
Wed 10/21/2015 01:24:56 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 80    PEEK   (80)
Wed 10/21/2015 01:24:56 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:24:56 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:24:58 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:24:58 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:24:58 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FC
Wed 10/21/2015 01:24:58 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FC 06          PEEK   (FC)
Wed 10/21/2015 01:24:58 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 0B    PEEK   (0B)
Wed 10/21/2015 01:24:58 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:24:58 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:24:59 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:24:59 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:24:59 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FD
Wed 10/21/2015 01:24:59 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FD 06          PEEK   (FD)
Wed 10/21/2015 01:24:59 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B FF    PEEK   (FF)
Wed 10/21/2015 01:24:59 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:24:59 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:00 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:00 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:00 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FE
Wed 10/21/2015 01:25:00 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FE 06          PEEK   (FE)
Wed 10/21/2015 01:25:00 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:00 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:00 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:02 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:02 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:02 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FF
Wed 10/21/2015 01:25:02 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FF 06          PEEK   (FF)
Wed 10/21/2015 01:25:02 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:02 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:02 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:03 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:03 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:03 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F0
Wed 10/21/2015 01:25:03 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F0 06          PEEK   (F0)
Wed 10/21/2015 01:25:03 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 22    PEEK   (22)
Wed 10/21/2015 01:25:03 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:03 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:04 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:04 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:04 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B E8
Wed 10/21/2015 01:25:04 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B E8 06          PEEK   (E8)
Wed 10/21/2015 01:25:04 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 22    PEEK   (22)
Wed 10/21/2015 01:25:04 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:04 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:05 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:05 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:05 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B E0
Wed 10/21/2015 01:25:05 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B E0 06          PEEK   (E0)
Wed 10/21/2015 01:25:06 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:06 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:06 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:06 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:06 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:06 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F8
Wed 10/21/2015 01:25:06 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F8 06          PEEK   (F8)
Wed 10/21/2015 01:25:07 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B A2    PEEK   (A2)
Wed 10/21/2015 01:25:07 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:07 AM : [18 EE 8F 1  ] MorningLinc database accessible
Wed 10/21/2015 01:25:07 AM : [18 EE 8F 1  ] Start : Adding device to ISY
Wed 10/21/2015 01:25:07 AM : [18 EE 8F 1  ] Finish : Adding device to ISY was Successful
Wed 10/21/2015 01:25:07 AM : [18 EE 8F 1  ] Link    0 : 0FF8 [A20022800BFF0000] Saving  [A20022800BFF0000]
Wed 10/21/2015 01:25:07 AM : [18 EE 8F 2  ] Start : Adding device to ISY
Wed 10/21/2015 01:25:07 AM : [18 EE 8F 2  ] Finish : Adding device to ISY was Successful
Wed 10/21/2015 01:25:08 AM : [18 EE 8F 2  ] Link    1 : 0FF0 [A20022800BFF0001] Saving  [A20022800BFF0001]
Wed 10/21/2015 01:25:08 AM : [18 EE 8F 0  ] Successfully added device
Wed 10/21/2015 01:25:08 AM : ---- Start: Generate Scenes from links ----
Wed 10/21/2015 01:25:12 AM : ---- End: Generate Scenes from links ----
Wed 10/21/2015 01:25:13 AM : [All         ] Writing 16 bytes to devices
Wed 10/21/2015 01:25:13 AM : [18 EE 8F 1  ] Link    0 : 0FF8 [A20022800BFF0000] Writing [A20022800BFF0000]
Wed 10/21/2015 01:25:13 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:13 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:13 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:13 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:13 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F8
Wed 10/21/2015 01:25:14 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F8 06          PEEK   (F8)
Wed 10/21/2015 01:25:14 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B A2    PEEK   (A2)
Wed 10/21/2015 01:25:14 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:14 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:14 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:14 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:14 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F9
Wed 10/21/2015 01:25:15 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F9 06          PEEK   (F9)
Wed 10/21/2015 01:25:15 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:15 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:15 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:15 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:15 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:15 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FA
Wed 10/21/2015 01:25:16 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FA 06          PEEK   (FA)
Wed 10/21/2015 01:25:16 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 22    PEEK   (22)
Wed 10/21/2015 01:25:16 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:16 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:16 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:16 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:16 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FB
Wed 10/21/2015 01:25:17 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FB 06          PEEK   (FB)
Wed 10/21/2015 01:25:17 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 80    PEEK   (80)
Wed 10/21/2015 01:25:17 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:17 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:17 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:17 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:17 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FC
Wed 10/21/2015 01:25:18 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FC 06          PEEK   (FC)
Wed 10/21/2015 01:25:18 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 0B    PEEK   (0B)
Wed 10/21/2015 01:25:18 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:18 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:18 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:18 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:18 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FD
Wed 10/21/2015 01:25:19 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FD 06          PEEK   (FD)
Wed 10/21/2015 01:25:19 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B FF    PEEK   (FF)
Wed 10/21/2015 01:25:19 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:19 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:19 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:19 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:19 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FE
Wed 10/21/2015 01:25:20 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FE 06          PEEK   (FE)
Wed 10/21/2015 01:25:20 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:20 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:20 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:20 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:20 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:20 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B FF
Wed 10/21/2015 01:25:21 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B FF 06          PEEK   (FF)
Wed 10/21/2015 01:25:21 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:21 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:21 AM : [MNG-LNK-RSP ] 02 6F 40 E2 00 18 EE 8F 0F 06 3A 15
Wed 10/21/2015 01:25:21 AM : [PLM         ] Group   0 : Writing Controller Link matching [18 EE 8F 1  ] Link    0 : 0FF8 [A20022800BFF0000]
Wed 10/21/2015 01:25:21 AM : [18 EE 8F 1  ] Link    1 : 0FF0 [A20022800BFF0001] Writing [A20022800BFF0001]
Wed 10/21/2015 01:25:21 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:22 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:22 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:22 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:22 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F0
Wed 10/21/2015 01:25:22 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F0 06          PEEK   (F0)
Wed 10/21/2015 01:25:22 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 22    PEEK   (22)
Wed 10/21/2015 01:25:22 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 29 A2
Wed 10/21/2015 01:25:23 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 29 A2 06          POKE   (A2)
Wed 10/21/2015 01:25:23 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 29 A2    POKE   (A2)
Wed 10/21/2015 01:25:23 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:23 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F1
Wed 10/21/2015 01:25:23 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F1 06          PEEK   (F1)
Wed 10/21/2015 01:25:23 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:23 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:24 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:24 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:24 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:24 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F2
Wed 10/21/2015 01:25:24 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F2 06          PEEK   (F2)
Wed 10/21/2015 01:25:24 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:24 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 29 22
Wed 10/21/2015 01:25:25 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 29 22 06          POKE   (22)
Wed 10/21/2015 01:25:25 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 29 22    POKE   (22)
Wed 10/21/2015 01:25:25 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:25 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F3
Wed 10/21/2015 01:25:25 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F3 06          PEEK   (F3)
Wed 10/21/2015 01:25:26 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:26 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:26 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 29 80
Wed 10/21/2015 01:25:26 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 29 80 06          POKE   (80)
Wed 10/21/2015 01:25:27 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 29 80    POKE   (80)
Wed 10/21/2015 01:25:27 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:27 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F4
Wed 10/21/2015 01:25:27 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F4 06          PEEK   (F4)
Wed 10/21/2015 01:25:27 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:27 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 29 0B
Wed 10/21/2015 01:25:27 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 29 0B 06          POKE   (0B)
Wed 10/21/2015 01:25:28 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 29 0B    POKE   (0B)
Wed 10/21/2015 01:25:28 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:28 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F5
Wed 10/21/2015 01:25:28 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F5 06          PEEK   (F5)
Wed 10/21/2015 01:25:28 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:28 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 29 FF
Wed 10/21/2015 01:25:28 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 29 FF 06          POKE   (FF)
Wed 10/21/2015 01:25:29 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 29 FF    POKE   (FF)
Wed 10/21/2015 01:25:29 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:29 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F6
Wed 10/21/2015 01:25:29 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F6 06          PEEK   (F6)
Wed 10/21/2015 01:25:29 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:29 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:29 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:30 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:30 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:30 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B F7
Wed 10/21/2015 01:25:30 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B F7 06          PEEK   (F7)
Wed 10/21/2015 01:25:30 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:30 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 29 01
Wed 10/21/2015 01:25:30 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 29 01 06          POKE   (01)
Wed 10/21/2015 01:25:31 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 29 01    POKE   (01)
Wed 10/21/2015 01:25:31 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:31 AM : [MNG-LNK-RSP ] 02 6F 40 E2 00 18 EE 8F 0F 06 3A 15
Wed 10/21/2015 01:25:31 AM : [PLM         ] Group   0 : Writing Controller Link matching [18 EE 8F 1  ] Link    1 : 0FF0 [A20022800BFF0001]
Wed 10/21/2015 01:25:31 AM : [18 EE 8F 1  ] Link    3 : 0FE0 [0000000000000000] Writing [00..............]
Wed 10/21/2015 01:25:31 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:31 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:32 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:32 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:32 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B E0
Wed 10/21/2015 01:25:32 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B E0 06          PEEK   (E0)
Wed 10/21/2015 01:25:32 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:32 AM : [18 EE 8F 1  ] Link    4 : 0FD8 : Writing High Water Byte
Wed 10/21/2015 01:25:32 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 28 0F
Wed 10/21/2015 01:25:33 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 28 0F 06          SET-MSB(0F)
Wed 10/21/2015 01:25:33 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 28 0F    SET-MSB(0F)
Wed 10/21/2015 01:25:33 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:33 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 2B D8
Wed 10/21/2015 01:25:33 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 2B D8 06          PEEK   (D8)
Wed 10/21/2015 01:25:33 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 2B 00    PEEK   (00)
Wed 10/21/2015 01:25:34 AM : [All         ] Writing 0 bytes to devices
Wed 10/21/2015 01:25:44 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 11 FF
Wed 10/21/2015 01:25:44 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 11 FF 06          LTONRR (FF)
Wed 10/21/2015 01:25:44 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 11 FF    LTONRR (FF)
Wed 10/21/2015 01:25:44 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:44 AM : [D2D EVENT   ] Event [18 EE 8F 2] [sT] [255] uom=0 prec=-1
Wed 10/21/2015 01:25:44 AM : [  18 EE 8F 2]       ST 255
Wed 10/21/2015 01:25:44 AM : [D2D EVENT   ] Event [18 EE 8F 1] [sT] [255] uom=0 prec=-1
Wed 10/21/2015 01:25:44 AM : [  18 EE 8F 1]       ST 255
Wed 10/21/2015 01:25:50 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 11 00
Wed 10/21/2015 01:25:50 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 11 00 06          LTONRR (00)
Wed 10/21/2015 01:25:50 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 11 00    LTONRR (00)
Wed 10/21/2015 01:25:50 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:50 AM : [D2D EVENT   ] Event [18 EE 8F 2] [sT] [0] uom=0 prec=-1
Wed 10/21/2015 01:25:50 AM : [  18 EE 8F 2]       ST   0
Wed 10/21/2015 01:25:50 AM : [D2D EVENT   ] Event [18 EE 8F 1] [sT] [0] uom=0 prec=-1
Wed 10/21/2015 01:25:50 AM : [  18 EE 8F 1]       ST   0
Wed 10/21/2015 01:25:55 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 11 FF
Wed 10/21/2015 01:25:55 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 11 FF 06          LTONRR (FF)
Wed 10/21/2015 01:25:55 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 11 FF    LTONRR (FF)
Wed 10/21/2015 01:25:55 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:25:55 AM : [D2D EVENT   ] Event [18 EE 8F 2] [sT] [255] uom=0 prec=-1
Wed 10/21/2015 01:25:55 AM : [  18 EE 8F 2]       ST 255
Wed 10/21/2015 01:25:55 AM : [D2D EVENT   ] Event [18 EE 8F 1] [sT] [255] uom=0 prec=-1
Wed 10/21/2015 01:25:55 AM : [  18 EE 8F 1]       ST 255
Wed 10/21/2015 01:26:03 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 11 00
Wed 10/21/2015 01:26:03 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 11 00 06          LTONRR (00)
Wed 10/21/2015 01:26:04 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 11 00    LTONRR (00)
Wed 10/21/2015 01:26:04 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:26:04 AM : [D2D EVENT   ] Event [18 EE 8F 2] [sT] [0] uom=0 prec=-1
Wed 10/21/2015 01:26:04 AM : [  18 EE 8F 2]       ST   0
Wed 10/21/2015 01:26:04 AM : [D2D EVENT   ] Event [18 EE 8F 1] [sT] [0] uom=0 prec=-1
Wed 10/21/2015 01:26:04 AM : [  18 EE 8F 1]       ST   0
Wed 10/21/2015 01:26:10 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 11 FF
Wed 10/21/2015 01:26:10 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 11 FF 06          LTONRR (FF)
Wed 10/21/2015 01:26:11 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 11 FF    LTONRR (FF)
Wed 10/21/2015 01:26:11 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:26:11 AM : [D2D EVENT   ] Event [18 EE 8F 1] [sT] [255] uom=0 prec=-1
Wed 10/21/2015 01:26:11 AM : [  18 EE 8F 1]       ST 255
Wed 10/21/2015 01:26:11 AM : [D2D EVENT   ] Event [18 EE 8F 2] [sT] [255] uom=0 prec=-1
Wed 10/21/2015 01:26:11 AM : [  18 EE 8F 2]       ST 255
Wed 10/21/2015 01:26:15 AM : [iNST-TX-I1  ] 02 62 18 EE 8F 0F 11 00
Wed 10/21/2015 01:26:15 AM : [iNST-ACK    ] 02 62 18.EE.8F 0F 11 00 06          LTONRR (00)
Wed 10/21/2015 01:26:15 AM : [iNST-SRX    ] 02 50 18.EE.8F 22.80.0B 2B 11 00    LTONRR (00)
Wed 10/21/2015 01:26:15 AM : [std-Direct Ack] 18.EE.8F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 10/21/2015 01:26:15 AM : [D2D EVENT   ] Event [18 EE 8F 1] [sT] [0] uom=0 prec=-1
Wed 10/21/2015 01:26:15 AM : [  18 EE 8F 1]       ST   0
Wed 10/21/2015 01:26:15 AM : [D2D EVENT   ] Event [18 EE 8F 2] [sT] [0] uom=0 prec=-1
Wed 10/21/2015 01:26:15 AM : [  18 EE 8F 2]       ST   0
I have no idea what you're doing with that very long post but your suggestion to use Start Linking worked very well.  I have never used the Start Linking approach, always preferring the Add Insteon Device route.  For some reason Add Insteon Device did not play well this time.
Thank you
