PLM Bad? Cannot Communicate w/ Any Devices
I was having trouble communicating with my Garage Door.  I rebooted my ISY and when it came up all the sudden it said it could not communicate with my devices.
In PLM Info/Status it Says "Connected"
In PLM Links Table Count it says "0" (I wonder if when I tried to restore it somehow on the PLM links got wiped?)
I powered everything off and then reconnected the PLM first.  The LED light is lit.  I then restored power to my ISY 994i v4.3.26.  I have attempted to restore the PLM once but I couldn't tell if it took.  The ISY is currently still working on stuff after the reboot so I can't really tell what is going on.  It keeps popping up with cannot communicate with xyz etc...
PLM Info = #2413S v2.0 1444 (Smarthome)
Suggestions?
It has the symptoms of a dead/dying PLM
You can try Restore PLM to resuscitate it until you replace it... that may work for a little while.
Ok,
My ISY calmed down and finished it's process after the reboot.  Looks like it still can't connect to devices.  My PLM links table shows "0".  I tried to restore the PLM and did not get any pop up errors.  My PLM links table still shows "0".  I assume that is not normal correct?  Should I try to replace the PLM at this point? My PLM is 10 months old.
