KPL Button Issue
I have a 6 button KPL that has been working for several years.  Just recently when I push the main "off" button the light on Button A goes off.  Buttons A and B are set to non-toggle on and buttons C and D are set to non-toggle off.  If I press button A again, the light comes on.  The main button and button A are not connected in any scenes.  Any ideas?
I would try a factory reset and then use the admin console to restore device and retest.
Sometimes insteon devices lose their way and need to be reprogrammed, and its a relatively quick procedure. The other possibility is that its going bad, but I have not witnessed this particular behavior before. What year did you buy it? Between 2011-2012, these had some manufacturing problems.
Paul
