Run Program Using REST from Batch File
zerop
Is it possible to run programs using the REST from a windows batch file?
I've got Tasker working on my Android phone using REST to run several programs so I know the basic setup for it, but I don't know how to do it from a batch file on Windows 7 64-bit.  If it's possible could someone point me in the right direction or is it pretty complicated?
Posted (edited)
Hi zerop,
/rest/programs/<id>/<cmd>
Example:
/rest/programs/0032/runThen
<cmd> could be any of the following:
run|runThen|runElse|stop|enable|disable|enableRunAtStartup|disableRunAtStartup
Yes, I understand that but how do you initiate this in the batch file?  In Tasker I use the HTTP Get with the following:
http://username:password@IP:port/rest/programs/programID/runThen
I can't run this same thing from the command line/batch file, it doesn't work.  Could someone provide example text for a batch file?
Edited by zerop
Posted (edited)
Batch files cannot themselves call a rest api. You'll need to find a helper binary, such as curl or wget (compiled for windows) and then use that as a command in your batch file to call the api.
Edited by MWareman
      37.9k
      379k
