November 30, 201510 yr I finally got my thermostat! I added it to my ISY and all looked good. I was able to manually control the thermostat thru the admin console. But the two issues I have are:I can't control it thru programs.The thermostat shows no status in MobiLinc.
November 30, 201510 yr I can't control it thru programs. That's somewhat vague. What specifically are you trying to do? What have you tried? Here's a few of my programs: Turn on cooling If Control 'BR / Devices / BRR HVAC.1 Heat-Zone 2 Off / BRR HVAC.3 Cool-Zone 1 Off' is switched On Then Set 'BR / Devices / BR Thermostat Main' 76° (Cool Setpoint) Set 'BR / Devices / BR Thermostat Main' Mode Cool Else - No Actions - (To add one, press 'Action') Turn the thermostat down 1º If Control 'BR / Devices / BRR HVAC.1 Heat-Zone 2 Off' is switched Dim Or Control 'BR / Devices / BRR HVAC.1 Heat-Zone 2 Off / BRR HVAC.3 Cool-Zone 1 Off' is switched Dim Then Set 'BR / Devices / BR Thermostat Main' Setpoint Down 1° Else - No Actions - (To add one, press 'Action') Turn the thermostat off If Control 'BR / Devices / BRR HVAC.1 Heat-Zone 2 Off' is switched Off Then Set 'BR / Devices / BR Thermostat Main' Mode Off Else - No Actions - (To add one, press 'Action') In each case, the trigger is a RemoteLinc button. I can't help you with MobiLinc, but Wes can: http://forum.univers...um/35-mobilinc/ I can add that all my Insteon thermostats are fully functional in MobiLinc.
November 30, 201510 yr Author When ever I try to do any programs with it I do not get thermostat option. The options I get are the options you would get if you're trying to program a dimmer switched. Sent from my SCH-I545 using Tapatalk
January 27, 201610 yr Has this been resolved? I am having the same issue when it comes to my ISY treating the thermostat as if it is a light rather than a thermostat when it comes to programming?
January 27, 201610 yr Hi rebirth24, Please makes sure you have UI version 4.4.2. With kind regards, Michel
January 30, 201610 yr Hi rebirth24, Please makes sure you have UI version 4.4.2. With kind regards, Michel Definitely have.
February 1, 201610 yr Hi rebirth24, Thank you. Please go to http://your-isy-ip-address/rest/nodes, save, and send it to support@universal-devices.com and highlight the thermostat node. With kind regards, Michel
February 1, 201610 yr Hi rebirth24, Thank you. Please go to http://your-isy-ip-address/rest/nodes, save, and send it to support@universal-devices.com and highlight the thermostat node. With kind regards, Michel Sent.
