Thermostat Issues
I've posted this now in numerous topics with no solutions yet.  I have the following:
ISY 994i/IR Pro v 4.3.26
Insteon Heat Pump Thermostat 2732-242
When ever I add this to the ISY it does not show me current state.  Also I've added a picture of the options I get when I try to add it to programs,  It acts like a light.  Please help.
Hello,
I would humbly suggest you engage UDI directly about this matter for the quickest and direct path for resolution. Given this device is so brand new its probably not a surprise that not all elements have been incorporated as required.
UDI over the years has tried to follow what the developer documents say. But sometimes the e-docs and hardware do not agree with one another and thus further root cause analysis is required.
You may send a service request using this resource link: http://www.universal-devices.com/contact-support/
Please reference this thread and do follow up with the work group.
I don't think it's being properly linked... There are a couple different methods.. Auto Discover or you can select the device...  which have you tried and, if you're selecting, which option are you using?
Jon...
I've tried auto and selecting.  I've tried selecting multiple types and they all do the same.
Stu posted an image of it properly linked...  you might first factory reset before adding..
Jon..
This is a new device so you'll probably need the latest firmware.
So.. what Firmware and UI version are you using?
Jon...
It's a wireless device and possible comms are bad when linking.   If you have a lamplinc or any range extender you might try plugging nearby.  Open Event viewer to Level 3 and record linking events and post back.
Jon...
Jon...
Just checked and they are the same.
But, it it the latest?
Fri 12/04/2015 04:00:18 PM : Setting Time From NTP
Fri 12/04/2015 04:00:27 PM : [34 d4 9d    ] Added to list of devices to link to ISY
Fri 12/04/2015 04:00:27 PM : [iNST-TX-I1  ] 02 62 34 D4 9D 0F 0D 00
Fri 12/04/2015 04:00:27 PM : [iNST-ACK    ] 02 62 34.D4.9D 0F 0D 00 06                 (00)
Fri 12/04/2015 04:00:27 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 0D 02           (02)
Fri 12/04/2015 04:00:27 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:27 PM : [iNST-TX-I1  ] 02 62 34 D4 9D 0F 10 00
Fri 12/04/2015 04:00:27 PM : [iNST-ACK    ] 02 62 34.D4.9D 0F 10 00 06          ID-REQ (00)
Fri 12/04/2015 04:00:27 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 10 00    ID-REQ (00)
Fri 12/04/2015 04:00:28 PM : [iNST-SRX    ] 02 50 34.D4.9D 05.13.11 8F 01 36           (36)
Fri 12/04/2015 04:00:28 PM : [std-Broadcast] 34.D4.9D-->05.13.11, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:28 PM : [34 D4 9D 0  ] Calibrating engine version
Fri 12/04/2015 04:00:28 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Fri 12/04/2015 04:00:28 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Fri 12/04/2015 04:00:28 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2F 00           (00)
Fri 12/04/2015 04:00:28 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:29 PM : [iNST-ERX    ] 02 51 34 D4 9D 30 6C 78 15 2F 00 00 01 1F FF 01 E2 EF 30 6C 78 01 00 EF DC
Fri 12/04/2015 04:00:29 PM : [Ext-Direct  ] 34.D4.9D-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Fri 12/04/2015 04:00:29 PM : [34 D4 9D 0  ] Using Database Link Table offset 0x1FF8 (reported 0x1FF8)
Fri 12/04/2015 04:00:29 PM : [34 D4 9D 1  ] Start : Adding device to ISY
Fri 12/04/2015 04:00:29 PM : [34 D4 9D 1  ] Finish : Adding device to ISY was Successful
Fri 12/04/2015 04:00:29 PM : [34 D4 9D 1  ] Link    0 : 1FF8 [E2EF306C780100EF] Saving  [E2EF306C780100EF]
Fri 12/04/2015 04:00:29 PM : [34 D4 9D 2  ] Start : Adding device to ISY
Fri 12/04/2015 04:00:29 PM : [34 D4 9D 2  ] Finish : Adding device to ISY was Successful
Fri 12/04/2015 04:00:29 PM : [34 D4 9D 2  ] Link    1 : 1FF0 [E201306C78010001] Saving  [E201306C78010001]
Fri 12/04/2015 04:00:29 PM : [34 D4 9D 3  ] Start : Adding device to ISY
Fri 12/04/2015 04:00:29 PM : [34 D4 9D 3  ] Finish : Adding device to ISY was Successful
Fri 12/04/2015 04:00:29 PM : [34 D4 9D 3  ] Link    2 : 1FE8 [E202306C78010002] Saving  [E202306C78010002]
Fri 12/04/2015 04:00:29 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96
Fri 12/04/2015 04:00:30 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96 06        (02)
Fri 12/04/2015 04:00:30 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2E 02           (02)
Fri 12/04/2015 04:00:30 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:39 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96
Fri 12/04/2015 04:00:39 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96 06        (02)
Fri 12/04/2015 04:00:40 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2E 02           (02)
Fri 12/04/2015 04:00:40 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:49 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96
Fri 12/04/2015 04:00:49 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96 06        (02)
Fri 12/04/2015 04:00:49 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2E 02           (02)
Fri 12/04/2015 04:00:49 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:53 PM : [34 D4 9D 0  ] Successfully added device
Fri 12/04/2015 04:00:54 PM : [All         ] Writing 25 bytes to devices
Fri 12/04/2015 04:00:54 PM : [34 D4 9D 1  ] Link    0 : 1FF8 [E2EF306C780100EF] Writing [E2EF306C780100EF]
Fri 12/04/2015 04:00:54 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2F 00 00 02 1F FF 08 E2 EF 30 6C 78 01 00 EF D4
Fri 12/04/2015 04:00:54 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2F 00 00 02 1F FF 08 E2 EF 30 6C 78 01 00 EF D4 06        (00)
Fri 12/04/2015 04:00:54 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2F 00           (00)
Fri 12/04/2015 04:00:54 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:54 PM : [MNG-LNK-RSP ] 02 6F 41 A2 EF 34 D4 9D 05 13 11 15
Fri 12/04/2015 04:00:54 PM : [PLM         ] Group 239 : Writing Responder Link matching [34 D4 9D 1  ] Link    0 : 1FF8 [E2EF306C780100EF]
Fri 12/04/2015 04:00:55 PM : [34 D4 9D 1  ] Link    1 : 1FF0 [E201306C78010001] Writing [E201306C78010001]
Fri 12/04/2015 04:00:55 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2F 00 00 02 1F F7 08 E2 01 30 6C 78 01 00 01 B8
Fri 12/04/2015 04:00:55 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2F 00 00 02 1F F7 08 E2 01 30 6C 78 01 00 01 B8 06        (00)
Fri 12/04/2015 04:00:55 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2F 00           (00)
Fri 12/04/2015 04:00:55 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:55 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 34 D4 9D 05 13 11 06
Fri 12/04/2015 04:00:55 PM : [PLM         ] Group   1 : Writing Responder Link matching [34 D4 9D 1  ] Link    1 : 1FF0 [E201306C78010001]
Fri 12/04/2015 04:00:56 PM : [34 D4 9D 1  ] Link    2 : 1FE8 [E202306C78010002] Writing [E202306C78010002]
Fri 12/04/2015 04:00:56 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2F 00 00 02 1F EF 08 E2 02 30 6C 78 01 00 02 BE
Fri 12/04/2015 04:00:56 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2F 00 00 02 1F EF 08 E2 02 30 6C 78 01 00 02 BE 06        (00)
Fri 12/04/2015 04:00:56 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2F 00           (00)
Fri 12/04/2015 04:00:56 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:57 PM : [MNG-LNK-RSP ] 02 6F 41 A2 02 34 D4 9D 05 13 11 06
Fri 12/04/2015 04:00:57 PM : [PLM         ] Group   2 : Writing Responder Link matching [34 D4 9D 1  ] Link    2 : 1FE8 [E202306C78010002]
Fri 12/04/2015 04:00:57 PM : [34 D4 9D 1  ] Link    3 : 1FE0 [0000000000000000] Writing [00..............]
Fri 12/04/2015 04:00:57 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2F 00 00 02 1F E7 08 00 00 00 00 00 00 00 00 C1
Fri 12/04/2015 04:00:57 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2F 00 00 02 1F E7 08 00 00 00 00 00 00 00 00 C1 06        (00)
Fri 12/04/2015 04:00:57 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2F 00           (00)
Fri 12/04/2015 04:00:57 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:57 PM : [34 D4 9D 1  ] Link    4 : 1FD8 : Writing High Water Byte
Fri 12/04/2015 04:00:57 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2F 00 00 00 1F DF 01 00 00 00 00 00 00 00 00 D2
Fri 12/04/2015 04:00:57 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2F 00 00 00 1F DF 01 00 00 00 00 00 00 00 00 D2 06        (00)
Fri 12/04/2015 04:00:58 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2F 00           (00)
Fri 12/04/2015 04:00:58 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:58 PM : [iNST-ERX    ] 02 51 34 D4 9D 30 6C 78 15 2F 00 00 01 1F DF 01 00 00 00 00 00 00 00 00 D1
Fri 12/04/2015 04:00:58 PM : [Ext-Direct  ] 34.D4.9D-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Fri 12/04/2015 04:00:58 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2F 00 00 00 1F DF 01 00 00 00 00 00 00 00 00 D2
Fri 12/04/2015 04:00:58 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2F 00 00 00 1F DF 01 00 00 00 00 00 00 00 00 D2 06        (00)
Fri 12/04/2015 04:00:59 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2F 00           (00)
Fri 12/04/2015 04:00:59 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:00:59 PM : [iNST-ERX    ] 02 51 34 D4 9D 30 6C 78 15 2F 00 00 01 1F DF 01 00 00 00 00 00 00 00 00 D1
Fri 12/04/2015 04:00:59 PM : [Ext-Direct  ] 34.D4.9D-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Fri 12/04/2015 04:00:59 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2F 00 00 02 1F DF 08 00 00 00 00 00 00 00 00 C9
Fri 12/04/2015 04:00:59 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2F 00 00 02 1F DF 08 00 00 00 00 00 00 00 00 C9 06        (00)
Fri 12/04/2015 04:01:00 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2F 00           (00)
Fri 12/04/2015 04:01:00 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:01:00 PM : [34 D4 9D 1  ] Memory : Write dbAddr=0x5001 [00] cmd1=0x2E cmd2=0x00
Fri 12/04/2015 04:01:00 PM : [iNST-TX-I2CS] 02 62 34 D4 9D 1F 2E 00 00 08 00 00 00 00 00 00 00 00 00 00 00 CA
Fri 12/04/2015 04:01:00 PM : [iNST-ACK    ] 02 62 34.D4.9D 1F 2E 00 00 08 00 00 00 00 00 00 00 00 00 00 00 CA 06        (00)
Fri 12/04/2015 04:01:01 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2E 00           (00)
Fri 12/04/2015 04:01:01 PM : [std-Direct Ack] 34.D4.9D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 12/04/2015 04:02:22 PM : [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 05 6F 1F           (1F)
Fri 12/04/2015 04:02:22 PM : [std-Direct  ] 34.D4.9D-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Fri 12/04/2015 04:02:22 PM : [D2D EVENT   ] Event [34 D4 9D 1] [CLIHUM] [31] uom=0 prec=-1
Fri 12/04/2015 04:02:22 PM : [  34 D4 9D 1]   CLIHUM  31
As far as I know.
I don't see anything wrong in the trace.. comms look good so??
I'm not certain about this line ---> Link    3 : 1FE0 [0000000000000000] Writing [00..............]
maybe someone else can point something out.
Jon...
You need to factory reset the device after each attempt at linking...
I'm trying to find out what It's being linked as...
Jon...
Link 3 (all zeros) is the End of List link record.  This is correct.
Under Admin Console, what does Help | About show for
Firmware?
UI?
 4.3.26 on both
I don't believe 4.4.1 offers anything new in ways of supporting this TSTAT. But if you update the controller to the latest Beta this will at least confirm there is a bug in the support of this new device.
I think it's being added as a 2441ZTH --> [iNST-SRX    ] 02 50 34.D4.9D 30.6C.78 2F 2F 00
but I don't know :)
again.. you need to factory reset after each link attempt.
EDIT: Sorry looks correct --> [iNST-SRX    ] 02 50 34.D4.9D 05.13.
Jon...
With my 2441ZTH thermostats I had a lot of problem linking them properly.
IIRC I must factory reset them about four or five times before they linked in correctly. These thermostats seem to have some magic formula to factory reset them properly.
I am not sure if this model has a backup battery that will require removing but if not, it must have a very large carry over capacitor that make take several minutes to discharge before doing the factory reset power up. Check the online manual.
OK.  I was bored this week end sitting in a hotel.  So I upgraded my system to v5.0.2 to see if this would help.  I now can program most every thing.  The only thing I can't change is the mode thru programming.  The option is there but it doesn't work.  I'm now thinking everything is synced correctly now its a software issue with the ISY.  Guess I'll have to wait a bit longer for full functionality.
Did you submit that service request to UDI as I had suggested? This is the only way they will be able to track this issue and offer an official fix.
As I am sure you won't be the last person needing a remedy for this TSTAT.
