Accessing Multiple Thermostats on Android
Hello All.
I have the dreaded Mobilinc for Android. Seems I've found another reason to dislike this poorly designed app.
I can't navigate between my multiple tstats. I swipe from right-to-left and access the second one. However, I can't swipe back to the first after that. A left-to-right swipe opens the navigation pane. I have to exit out of Mobilinc to start over to get back to the first. I've tried swiping top-down, bottom-up, etc. Can't figure out a way.
Any suggestions?
Hello All.
Any suggestions?
Try swiping right to left again.
Mine seems to work just fine here with two stats. v5.0.2.
Do you know where that finger's been? :)
Tried that, too. Nada.
Samsung Galaxy 6 Edge.  Android v5.1.1. Mobilinc v2.0.7.
I actually had this problem on my previous Android phone also just never bothered with posting here.
I have a Droid Ultra. To change thermostat views I swipe right to left. If I want to go back to the first view, I swipe left to right.
shannong,
When swiping from left to right start closer to the middle of the screen and swipe to the right. Depending on the Android device as you get closer to the left edge of the screen the left to right swipe could be picked up as a menu open swipe by Android OS before the swipe is passed to MobiLinc.
Wes
