Write Device Update - Remote Battery Updating
Write Device Update 6 members have voted
1. Does write device update work for you
No - It does not work14%1
Yes - It works perfectly fine14%1
Depends - What the battery operated device is28%2
Works perfectly with the Motion Sensor14%1
Works fine with other battery operated devices.0%0
Does not work with other battery operated devices.0%0
I have no clue this feature even existed!28%2
I never use it because I want to do the updates manually.0%0
2. How many (wait) seconds do you use in the program that's proven to work?
0 - Seconds seems to work best.50%3
1 - Second seems to work the best0%0
2 - Seconds seems to work the best0%0
3 - Seconds seems to work the best0%0
4- Seconds or more is required0%0
Each sensor requires a different time interval even in the same product group.50%3
3. Can this feature be improved upon?
Yes - But have no clue how12%1
No - The feature works fine as it is12%1
Anything can be improved upon - It simply takes a investment in time25%2
The system should log and show a successful write update when completed50%4
Please sign in or register to vote in this poll.
Followers
