Device list
bmercier
Hi Mike,
Thank you. We do know Echo has problems with light, lights, bedroom. For instance, I had to use "master room" for bedroom.
So, what you might want to try (instead of light) is "room".
I've has success with four bedroom devices; bedroom ceiling, bedroom fan, bedroom fireplace and bedroom wall (Alexa does not like "sconces."). I have had only limited success with "dining room." (see posts #39 and #42).
In my experience, when I use the verbal command "Open Izzy", then follow with "Turn on dining room" or "Turn off dining room", then the device works as expected.  Only issue with this approach is having to go through the full UDI Alexa spiel each time.
However, when I issue verbal command "Tell Izzy to turn on dining room", then I get the response, that the device is not in my profile.  I currently only have the master account in ISY portal, investigating if I need to setup a separate user account.
Z3phyr.
Whenever you hear that it can't find a device in your "profile", this is a symptom that Alexa sent your request to the connected home. It was not routed to the skill.
Make sure to pronounce the "to" correctly. Alexa, tell izzy to turn on dining room.
You can look at the echo to see what she understands.
Benoit.
Benoit,
That's not the case here. I tried Z3phyr's method, that is, ""open Izzy," for the dining room light. When Alexa couldn't find the light (i.e., Turn on which device?), I repeated, "Dining room light." As expected Alexa said, once again, "Turn on which device?" This time, I responded with, "Dining room fan." The fan turned on and Alexa acknowledged that. So, the response was to the skill--without ever repeating "Izzy."
Benoit,
Stusview,
You request was indeed sent to the skill.
If you hear a reply which says "Turn on which device?", or "I could not find device <xyz>. Turn on which device?", then yes, the request was directed to the skill and it could not find the device.
However, if you hear "Sorry, I could not find a device or group name <device> in <user>'s profile", that's not coming from the skill. This means Alexa tried to find the device in the connected home profile. I believe this is the message that Z3phy got. One reason for this can be for Alexa not to understand "to" properly.
Benoit.
bmercier, on 09 Jan 2016 - 4:57 PM, said:
Stusview,
Benoit.
Thank Benoit.  When I clearly annunciate "to" Alexa does respond correctly with device command.
Z3phyr.
Benoit.
Also to assist others having similar issues, when the voice command is directed to connected home (i.e., "I could not find the device in {user} profile") it does not show up in the Echo voice command URL.  The skill commands do.
Benoit,
1. I asked Alexa to tell Izzy to turn on the dining room light. Alexa heard, "Alexa, tell Izzy to turn on the dining room light."  2. I said only, "Dining room light." Alexa heard, "dining room" 3. I then said, "Dining room fan." Alexa heard and turned on the dining room fan. Which part is Connected Home, which is the skill and how and when did it change?
Benoit,
Stusview,
Thanks for the screen capture, that helps understanding.
From what I see, it's a conversation which is all within the skill. Connected home is not involved at all here.
There are a few verbs that gets you into a skill, like:
open <skill>
tell <skill> to
ask <skill> to
In the case of tell and ask, it's the combination of the "verb + skill name + to" that routes the request to the skill. So, if Alexa does not understand the to, and clearly understands the turn on, she thinks it's for connected home. Even if you have no connected home adapter enabled.
When you are within a skill, and the skill asks you a question and leaves the stream open, then you can say something else (like a device name), and this gets routed to the skill currently opened. That happends when you ask for a command, and the device is not found, then the skill will ask a question and leave the stream open. Same thing goes when you are within the help.
Benoit.
Great progress, with the latest changes I have a number of devices and scenes now working, eager to see Programs added.
I have had to stick strictly to the list of Utterances and have a few additions to request where they make sense.
Thanks for all the hard work to get us this far.
Bob
Pool Table
Bonus Room
Exercise Room
Floor Lamp
Plant Shelf
Bathroom Ceiling
Toe kick
Art Niche
Flood Lights
Outdoor Kitchen
Table Lamp
Shade Down
Shade Up
Bonus Room Hall
Bonus Hall
Bonus Room Sconce
Bonus Sconces
Living Room Hall
Outdoor
Dog Door
All
Edited by bbuzzone
Program support is now available!
Benoit.
Thanks everyone for your suggestions.
A new version of the skill is about to be submitted for certification. Most of the suggestions in this thread were added to the sample devices.
Benoit.
Stusview,
open <skill>
tell <skill> to
ask <skill> to
Benoit.
Thanks Benoit, that helps a lot. I still don't know why dining room fan work but dining room light doesn't. I'll work on that for a while and post back.
Benoit.
Before I actually try, do I tell Izzy to run a program (by name) or do I simply give a program a unique name and ask Issy to turn the (program) name on?
You can do both. First of all, in both cases, you need to add your program to your list of spoken.
Then you can say:
tell izzy to turn on <program>: This Runs the then statement of the program
tell izzy to turn off <program>: This Runs the else statement of the program
tell izzy to run <program>: This Runs the program, considering the conditions of the program (runIf)
Benoit.
No need to try. light is passed to the skill, whereas fan is not.
Wait a bit more for the next version of the skill, both will work.
Benoit.
I have an ISY scene named "bar lights."  I have been trying to get the spoken name "bar" to work with Alexa.  She doesn't recognize it.  (She sometimes hears "barn," or can't find a device - "What device?")  Should "bar" work, or do I need to work on my enunciation?
I also have scenes with names like "morning," bedtime."  Any thought about adding this kind of words as device names?
New to this, so I appreciate any help.
Hold on, this is coming :-)
A new version of the skill is currently submitted for certification. That will work when it gets live.
Benoit.
I wasn't sure whether the long list in your earlier post were active or planned words.
Thanks for your help -- and to UDI for getting this going!
      379.9k
