2441TH thermostat minimum temperature
Does anyone happen to know what the minimum setpoint is on the 2441TH?  I am investigating the possibility of installing one in a garage where the normal winter setpoint will be 35 to 40F.
I am thinking of when the garage door is open via the IOlinc, I can with the ISY disable the furnace.
dave
I reported about a year back that my 2441ZTH worked down to about -2 degrees C. The reported temperature went into the 127 (254 bit count = -1) degree range with negative readings before it died frozen.
I didn't check the minimum setpoint setting IIRC.
The minimum heating setpoint on the 2441TH and 2441ZTH is 35ºF.
