Honeywell RTH9580WF & ISY?
Hello everyone,
Honeywell is the only company that actually approached us to add support for their WiFi thermostats (Comfort API) and even sent us a thermostat immediately! Since the solution is cloud based, we are going to have to use the ISY Portal. This said, we are going to working on it shortly and as soon as 5.0.3 is available.
Awesome, Michel. This will definitely make me a portal user!
Hello everyone,
Michel- Did they approach you for their new Lyric model or was it for the older Redlink thermostats via Redlink? This is a big difference.
Also if you have their ear maybe ask them if they will allow the ISY to control EVR ventilation in leu of the HVC20A1000/U
Wireless Vent and Filter Boost Remote with full access to the 180mins max time limit that is available on the thermostat but not on any of their wireless remotes. Found here -> https://www.forwardthinking.honeywell.com/products/wireless/wireless_products.html- This is a big deal for people who have EVRs like myself. We can't even use the Honeywell TCC website or mobile apps to control the EVR booster, it has to be done by the remote and max timeframe is 60mins when on the thermostat the max is 180mins. If you could mention that for even an update to their TCC apps and website would be awesome.
Lyric vs TCC is also a factor. Their Lyric API is fully available but does not work for other WiFi stats.
EXACTLY - So thats why I am wondering if when Honeywell Contacted them was it for the "Redlink" devices or the new Lyric. It wasn't specifically stated.
I thought when Michel said "Comfort API" that meant TCC?
Sent from my Nexus 6P using Tapatalk
You know what they say when you "assume" - thats why I specifically asked. I am not certain about anything when it comes to Honeywell :) Beta is open for Lyric and they are allowing devs access to APIs. I am not hear to bash or confuse the issue. Completely the opposite, I want to make sure Michel is specifically speaking about REDLINK and thermostats that use the Total Comfort Connect.
Teaser
Which Honeywell thermostat?
IO_Guys works with all compatible Redlink thermostats that connect to the Honeywell Total Comfort Connect website.
Edit: Added from my other thread,
Compatible TCC thermostats and their details can be found via pdf here:
http://www.forwardthinking.honeywell.com/related_links/thermostats/03-00005.pdf
Edited by huddadudda
Hi All,
This is for Comfort API. Just got the thermostat and sent it over to Benoit.
Michel I guess I am dense, what is the Comfort API? Does it work with Redlink or Lyric?
I would like to post I have now been contacted from Honeywell too for the Comfort Connect API access. Things are looking up!
  • 1 month later...
Just got an email from Honeywell this morning saying that this thermostat now has IFTTT support.
Sent from my SM-G935V using Tapatalk
Its been available for a while now. Maybe two months or so?
  • 2 months later...
I see that Amazon Echo now supports Honeywell Total Connect Comfort.
Amazon Echo & Honeywell bring voice control to your connected home
Life just got smarter
We've got big news for you. Amazon Echo can now control your Honeywell Total Connect Comfort Thermostat. Use Alexa, the voice service that powers Amazon Echo, to set the perfect temperature in your home by voice command. Simply say "Alexa, set my temperature to 72 degrees" and enjoy your home's comfort without having to lift a finger. Are you ready to bring the future to your home?
I will assume there might be a possibility to have the ISY control the Echo, which in turn can control Honeywell.
Add me to the long list of people who would love ISY integration with Honeywell.
Edited by Scott MS
Just tried this myself thanks for sharing. The thing is you can not turn on HEAT, AC or turn it OFF, this allows you to only change the setpoints in the current mode.
