'Ramp rate' and 'On level' don't appear to function.
Hi,
I've created a scene containing a single 'LampLink' device, attached is a lamp. The attributes are set to 60 (on level) and 19s (ramp rate) for the device within the scene.
The problem is that the lamp turns on to full straight away but does ramp down when turning off. I'd appreciate it if someone could point out the error or advise a way to correct the problem.
I have also created 3 programs as follows:
[bedroom Night Light On]
Set Scene 'Bedroom Night Light' Fade Up
[bedroom Night Light Off]
Set Scene 'Bedroom Night Light' Fade Down
[Motion Night Light - Main Bedroom]
From Sunset - 1 hours
For 15 hours
And Status '0A.43.15-Sensor' is On
Run Program 'Bedroom Night Light On' (Then Path)
Wait 2 minute
Run Program 'Bedroom Night Light Off' (Then Path)
Many thanks,
Wayne
Restoring the lamplink device fixed the problems.
Wayne
