Mobilinc Setup failing
I've installed Mobilinc Pro on my iPhone.  I get a message "Found SmartLinc at IP 192.168.1.xxx:xxxx.   This IP address does not match the one I have for my ISY in the DHCP table of my router.  It prompts me for my user name and password (I assume the credentials for my ISY).  I enter then and it cycles with a message "Please Wait Retrieving Rooms and Scenes" then I get a message "Connection Timeout Error Communicating with the SmartLinc.  Please verify your connection in My Settings."
I'm clueless at this point.
Use the address found in the admin console Help > About and the same password used for the admin console.
Jon...
I can't find anywhere to manually add the IP address in the app.
In Mobilinc > My Settings > Lighting Controller Settings
Jon...
Found it under Lighting controls. ????
Oops yup. Thanks!
