Slow response
flsenior
I just switched from MobiLinc Connect to the Isy portal because of my purchase of an Amazon Echo and the Connected Home. I find that my communication between MobiLinc Pro and my ISY is now incredibly slow. When I used MobiLinc Connect the communication was significantly faster.
Am I now doomed to this slow communication status or is there a solution available now or coming soon?
I am using an iPhone 5. All of my ISY and phone software is up to date.
My slow communication issues are most severe when using MobiLinc on my wifi network. In this situation the little communication wheel at the top of my phone spins and spins for a very long time. The response time to turn a device on/off is seconds.
My communication time when I am Not using my home wifi is a little faster but still considerably slower than when I used MobiLinc Connect.
I also find that the device indicator icon will not always update when a light is turned on/off even though the light did respond as desired.
Hi flsenior,
I'll have an official announcement here soon, but wanted to let you know that Amazon certified our MobiLinc skill for the Echo yesterday. You can now stay with MobiLinc Connect and use your Echo with our service. Just open the Alexa app and link your MobiLinc Connect account to the MobiLinc skill. Remember to reinstall the MobiLinc Connect portal in your ISY and remove the ISY Portal.
More on this later today!
Wes
I look forward to your announcement.  One question that I hope is answered is the communication protocol when using the MobiLinc Connect Skill.  With the Connected Home module my voice commands to the Echo are pretty straight forward, "Alexa, turn on the kitchen".  For the MobiLinc Skill do I have a longer command such as Alexa, turn on "MobiLinc Connect" and turn kitchen on.
I am trying to find the Utopian world of simple commands and fast, remote response from my iPhone.
flsenior,
The reason for slowness in your Wifi network is because MobiLinc is going through the portal at all times. What you might want to try is, in your MobiLinc Settings:
Http URL: the local IP address of your ISY at home. You can find it under Admin Console | Configuration | Network Settings
Http Port:: the Http port for your ISY ... usually 80. You can find it under Admin Console | Configuration | Network Settings | Http Port
I made the Http changes you advised but was not able to connect to the ISY.  I assume that I could not connect because the User ID and Password is wrong.  Here is my situation.
When I setup the ISY Portal, the sign in screen requested my email as the User ID.  My ISY is setup with a different ID.  The ISY Admin Console will not allow a user ID setup as long as my email address.  Must I use a valid email address as the user ID on the ISY Portal?
As far as I know the setting for Mobilinc and ISY Portal do not allow local IP because of difference in passwords so unless you create another profile for local you're always connected https to ISY Portal.
To configure Mobilinc use these setting...
Host Type = ISY
User Name = Portal Username (email address)
Password = Portal Login Password
Local http://= blank
Local Port = 80
Secure https:// = my.isy.io
Secure Port = 443
Connection Method = Secure Connection
Jon...
The way I've gotten local to work with the portal is to change my ISY userid and password to that of the Portal so it is possible you just need to have the same credentials.
Jon...
Hi flsenior,
I am so very sorry. That's correct and I had a lapse of senility.
Unfortunately unless MobiLinc decides to support ISY Portal, we are stuck here where EVERYTHING has to go to the portal even if local.
If you wish, you can send a request to sales@universal-devices.com and we'll remove and refund ISY Portal for you.
      37.6k
      376.2k
