Remotely put 2441TH thermostat on/off hold
The manual for the 2441TH thermostat states it can be remotely put on/off hold.
While I can physically do this at the thermosat, and can remotely control virtually all other functions via the ISY Admin Console and (and Mobilinc too), I can't see any option to set a temperature and put the thermostat on hold, or take it off of hold and resume program auto mode.
Can anyone else weigh in?
Something like this.  Ignore If
Leak3 - [iD 009E][Parent 0001]
        Control 'Leak Sensor 2-Dry / Leak Sensor 2-Wet' is switched On
        Set '2441TH - Main' Mode Off
        Set '2441TH - Main' 70° (Heat Setpoint)
        Set '2441TH - Main' Mode Auto
I accomplish something similar that with two programs for each possible mode, Cool, Heat, Auto and Program Auto plus a trigger program. The extra program is needed because setting the mode off ends the first program. The delay is to prevent all mode programs from running concurrently. Since you just want a hold you don't need a delay. Just add restart programs to Else.
Dine Out HVAC
   Place your trigger here
        Run Program 'LR Dine Out Cool 1' (If)
        Run Program 'LR Dine Out Heat 1' (If)
        Run Program 'BR Dine Out Auto 1' (If)
        Run Program 'BR Dine Out Prog 1' (If)
BR Dine Out Cool 1 [Not Enabled]
        Status  'BR / Devices / BR Thermostat Main' is Mode Cool
        Wait  4 seconds
        Run Program 'BR Dine Out Cool 2' (Then Path)
BR Dine Out Cool 2
        Set 'BR / Devices / BR Thermostat Main' Synchronize Clock
        Set 'BR / Devices / BR Thermostat Main' Mode Off
        Wait  1 hour
        Set 'BR / Devices / BR Thermostat Main' Mode Cool
