Programming Help
Hi All
Need help with a simple program.  I'd like my hidden door sensor to trigger a hallway light to come for 5 minutes when the sensor is switched on. This is what I have so far
test sensor - [ID 014B][Parent 0032]
        Status  '32.7A.4D.1 - Door Sensor' is Off
        Set 'Master Bedroom / M/Bedroom light' On
Edited by ldrinc
You want to use "Control" rather than status.  The hidden door sensor sends an off signal when door is closed.
Jon...
Hi
Update the If statement to use Control / switched on (as jerlands suggested), and add the 2 lines to the then clause
        Control '32.7A.4D.1 - Door Sensor' is switched On
        Wait 5 minutes
        Set 'Master Bedroom / M/Bedroom light' Off
Edited by paulbates
Thanks all...
Your suggestions fixed my issue.  Thanks again.
