Forcing an off command?
Hi,
I have a scene called all off.  I have a number of keypad buttons around the house (D button) that all do the same thing, they are set only to turn off & that tells the scene to turn off.
Is there a way to make echo only turn that scene off?
Otherwise attic fans & lights, fans, buzzers, all will start lighting up.
Rich
How about a program that calls that scene for false and nothing for true? Then have echo call that program instead of the scene.
A program is a great idea. You can put a statement that turns the scene off in both Then and Else. Then you can verbally turn the scene on or off and it will execute a scene off only.
