larryllix Posted October 14, 2016 Posted October 14, 2016 (edited) I hear ya. Each bulb type seems to have a different curve and I usually want the bottom reliable brightness level. That does make it hard to find one percentage level that would fit all. I have some that use about 10%, some 12% and some that don't work reliably below about 17%. With voice operating three or four scenes that level would have to be programmed for each application/bulb and then the spoken phrases could be standardised. So when we use the "brighten" command the step could just be in 3-4 discreet clicks and operate those on user presets matched to that bulb/device. Edited October 14, 2016 by larryllix
MustangChris04 Posted October 20, 2016 Author Posted October 20, 2016 Lets just agree that the current 10% is not enough Maybe one day we could say "Dim the lights a lot" or "Dim the lights a little". I believe the echo already responds to "turn up the volume a lot", or "turn down the volume a little", so maybe one day this can be done with the lights.
stusviews Posted October 20, 2016 Posted October 20, 2016 (edited) Why should I agree that 10% (actually 9%) is not enough when I find it adequate--depending on the starting level. I'll agree that we disagree BTW, if you control the device instead of a scene, then you can vocally set the On-level percentage. Edited October 20, 2016 by stusviews
larryllix Posted October 20, 2016 Posted October 20, 2016 (edited) I use a program from Alexa, I call sunset liyghts. In this program I set the perimeter lighting all to various shades of orange and red. The main lights in the ceiling are all white only. Over a period of an hour I dim all the white lights. In order to make white lights dim to finish about the same time I use a percentage for each dim period. This works very well. I do play the truncation factor in simple integer arithmetic also. If a bulb starts at 100% is becomes 90% If another bulb is already at 20% it becomes 18% These steps are barely visible to the human eye at any level. The same thing could be applied to the Echo but in larger steps, like log2. Just cut the level in half or double it each step. Stepping 9 or 10% at 100% level is hardly detectable, if at all while 9 or 10% at a 18% level will usually just turn most bulbs off completely. Edited October 20, 2016 by larryllix
