Subscribing to events via Portal
I seem to be having an issue with this.  I can send commands to the portal easy enough, but I can not seem to get a response from the portal when setting up a subscription to listen for events.  This same code works find when subscribing to the ISY directly.
private void doSubscribe(String auth) {
    SSLSocket isySocketSSL;
    Socket isySocket;
    try {
      if (aisy.getSSLEnabled()) {
        isySocketSSL = ConnectionManager.getSSLSocket(aisy);
        writer = new OutputStreamWriter(isySocketSSL.getOutputStream());
        reader = isySocketSSL.getInputStream();
      } else {
        isySocket = ConnectionManager.getSocket(aisy);
        writer = new OutputStreamWriter(isySocket.getOutputStream());
        reader = isySocket.getInputStream();
    } catch (Exception e) {
      e.printStackTrace();
      return;
    String subreq = "<s:Envelope><s:Body>" + "<u:Subscribe";
    subreq += " xmlns:u='urn:udi-com:service:X_Insteon_Lighting_Service:1'>";
    subreq += "<reportURL>REUSE_SOCKET</reportURL>";
    subreq += "<duration>infinite</duration>";
    subreq += "</u:Subscribe></s:Body></s:Envelope>";
    try {
      writer.write("POST /services HTTP/1.1\n");
      writer.write("Content-Type: text/xml; charset=utf-8\n");
      writer.write("Authorization: " + auth + "\n");
      writer.write("Content-Length: " + (subreq.length()) + "\n");
      writer.write("SOAPAction: urn:udi-com:device:X_Insteon_Lighting_Service:1#Subscribe\r\n");
      writer.write("\r\n");
      writer.write(subreq);
      writer.flush();
    } catch (IOException e) {
      setRunning(false);
      return;
    int content_length = 0;
    StringBuffer headerBuffer = new StringBuffer();
    int charValue;
    do { //Do once and then check for SID - REPEAT IF SID FOUND
      try {
//THIS IS AS FAR AS IT GETS - reader never gets any response data.
        while ((charValue = reader.read()) != -1) { //CONTINUE READING TILL END OF INPUT
          //DO STUFF
        Log.d(TAG,"Network Connection Lost");
        hasSID = false;
        if (listener != null)
          listener.onConnectionFailure();
      headerBuffer.setLength(0);
    } while (hasSID);
Hi James,
1. What URL are you posting to?
2. Do you have Preferred ISY set in My Profile (my.isy.io/top right corner)?
I was able to resolve this:  My SOAP knowledge is very limited so I don't really know shat I am doing with it.
I changed my request to :
      writer.write("Host: " + isy.getHost());
      writer.flush();
I guess I was adding some extra information that did not need to be included.  The ISY didn't mind, but it appears that the portal did.
