Aeon smart meter adding weird values
I have an Aeon labs smart meter (AEDSB09104ZWUS) that added fine initially, and has been reporting fine... I initially had two nodes.  node one included current power, and total power.  node two included battery level.
I was in the other day, and noticed that in node two in addition to battery level, it now showed oddly a speed in meters\sec for some odd reason..  a week later in node one in addition to the above it added current voltage (which I'm sure this meter cannot provide).  now just today in node one it also added pulse count (so now 4 items total in node 1, 2 in node 2).
Seems very odd to me.. only thing I've done on or around the times I noticed these extra items (I don't get in a lot to look) was add more zwave devices....
Is this a bug, oddity, ???
Well it's certainly an oddity.  And in as much as a bug can be defined as any unexpected or erroneous behavior, I'd say it's a bug, too.
With z-wave, the ISY doesn't know in advance what a z-wave device is capable of reporting upon, so whenever it gets a message that (for some reason) is damaged, it just adds it anyway, creating the extra items if it deems that necessary.
So my Leviton on/off switch now has a temperature sensor, at least according to the ISY.  Any my multisensor in the garage has suddenly begun to measure wind speed.
All you can do is delete the errant fields; deleting and re-adding the z-wave device will mess up your programs (the node ID will change).
ok..  now it's added a whole extra node with water volume...  and one of my smoke alarms now has an energy meter (power and total power) node, and multilevel node with rain rate.....  seems like more times goes on more oddities.  is this normal?  or any idea how to prevent?
Yeah, I really don't want to mess up my programs.. how do I delete an errant node or errant field in correct node without doing this?
1) Make an ISY backup
2) Delete all the ISY nodes for the device (don't exclude the device, just delete the ISY nodes right+click +> delete in the device tree).  Note you have to delete the primary node last (the one with address ending in "_1" e.g. "ZW003_1")
3) Do a Z-Wave -> Tools -> Synchronize Nodes -> New & Deleted
This will recreate the nodes as they were with the same addresses.  After you are done, restart the ISY.
Did all this.. I was able to delete the 'extra' isy nodes, however none of the valid zwave ISY nodes have the delete option available.. only disable..  I backed up, deleted 'extra' nodes, updated to 446 and after restart the valid nodes had only correct values.. however now its the next day and the 'extra' nodes are back and then some...  and the extra fields are also slowly adding themselves back into the valid nodes...
ideas?
nevermind, I had to remove them from a folder before could delete them..  will keep all posted
Anyone?  any more ideas?  it's quite a nuisance, or is this just going to be a zwave gimme on ISY?
this is all that shows.  Also here is a screenshot attached of what the invalid extra nodes look like.  FYI device 8 is a smoke alarm, 9 is an energy meter, and 11 is the minimote
Thu 04/21/2016 09:12:56 PM : [   ZW009_143]       ST 163294 (uom=73 prec=2)
Thu 04/21/2016 09:13:00 PM : [ZW-SHOW         ] ----------------------------------------------
Thu 04/21/2016 09:13:00 PM : [ZW-SHOW         ] ZW011_1 uid=11 type=1.1.1 mid=134 tid=1 pid=3 model=0
Thu 04/21/2016 09:13:00 PM : [ZW-SHOW         ]    -  x86  V0  VERSION
Thu 04/21/2016 09:13:00 PM : [ZW-SHOW         ]    -  x72  V1  MANUFACTURER_SPECIFIC
Thu 04/21/2016 09:13:00 PM : [ZW-SHOW         ]    -  x70  V1  CONFIGURATION
Thu 04/21/2016 09:13:00 PM : [ZW-SHOW         ]    -  x9B  V0  ASSOCIATION_COMMAND_CONFIGURATION
Thu 04/21/2016 09:13:00 PM : [ZW-SHOW         ]    -  xEF  V0  MARK
Thu 04/21/2016 09:13:00 PM : [ZW-SHOW         ]    -  x85  V0  ASSOCIATION
Thu 04/21/2016 09:13:00 PM : [ZW-SHOW         ]    -  x2B  V0  SCENE_ACTIVATION
Thu 04/21/2016 09:13:00 PM : [ZW-SHOW         ]    -  x26  V0  SWITCH_MULTILEVEL
Thu 04/21/2016 09:13:01 PM : [ZW-SHOW         ] Node  11 - ZWave Minimote has the following neighbors
Thu 04/21/2016 09:13:01 PM : [ZW-SHOW         ]    No Neighbors
Thu 04/21/2016 09:13:01 PM : [ZW-SHOW         ] Node  11 - ZWave Minimote does not support associations
Thu 04/21/2016 09:13:01 PM : [ZW-SHOW         ] ----------------------------------------------
Thu 04/21/2016 09:13:01 PM : [   ZW009_143]       ST 163491 (uom=73 prec=2)
Thu 04/21/2016 09:13:06 PM : [   ZW009_143]       ST 164155 (uom=73 prec=2)
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ] ----------------------------------------------
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ] ZW009_1 uid=9 type=4.33.1 mid=134 tid=2 pid=9 model=0
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ]    -  x70  V1  CONFIGURATION
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ]    -  x31  V2  SENSOR_MULTILEVEL
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ]    -  x72  V1  MANUFACTURER_SPECIFIC
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ]    -  x86  V0  VERSION
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ]    -  x32  V2  METER
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ]    -  x80  V0  BATTERY
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ]    -  x85  V1  ASSOCIATION
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ]    -  x60  V2  MULTI_INSTANCE
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ] Node   9 - House Energy Meter Battery has the following neighbors
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ]    -          - Node   1 - [This ISY]
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ]    - Repeater - Node   2 - Siren
Thu 04/21/2016 09:13:10 PM : [ZW-SHOW         ]    -          - Node  10 - Front Door
Thu 04/21/2016 09:13:11 PM : [ZW-SHOW         ] Node   9 - House Energy Meter Battery has 1 association group
Thu 04/21/2016 09:13:11 PM : [ZW-SHOW         ]    Associations for group 001 of ZW009_1 House Energy Meter Battery
Thu 04/21/2016 09:13:11 PM : [ZW-SHOW         ]       - Node   1 - [This ISY]
Thu 04/21/2016 09:13:11 PM : [ZW-SHOW         ]       - Node   8 - Master Bedroom Smoke Alarm
Thu 04/21/2016 09:13:11 PM : [ZW-SHOW         ]       - Node 126
Thu 04/21/2016 09:13:11 PM : [ZW-SHOW         ] ----------------------------------------------
Thu 04/21/2016 09:13:12 PM : [   ZW009_143]       ST 163840 (uom=73 prec=2)
Thu 04/21/2016 09:13:12 PM : [   ZW009_143]       ST 164057 (uom=73 prec=2)
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ] ----------------------------------------------
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ] ZW009_1 uid=9 type=4.33.1 mid=134 tid=2 pid=9 model=0
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ]    -  x70  V1  CONFIGURATION
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ]    -  x31  V2  SENSOR_MULTILEVEL
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ]    -  x72  V1  MANUFACTURER_SPECIFIC
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ]    -  x86  V0  VERSION
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ]    -  x32  V2  METER
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ]    -  x80  V0  BATTERY
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ]    -  x85  V1  ASSOCIATION
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ]    -  x60  V2  MULTI_INSTANCE
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ] Node   9 - House Energy Meter Battery has the following neighbors
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ]    -          - Node   1 - [This ISY]
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ]    - Repeater - Node   2 - Siren
Thu 04/21/2016 09:13:15 PM : [ZW-SHOW         ]    -          - Node  10 - Front Door
Thu 04/21/2016 09:13:16 PM : [ZW-SHOW         ] Node   9 - House Energy Meter Battery has 1 association group
Thu 04/21/2016 09:13:16 PM : [   ZW009_143]       ST 163503 (uom=73 prec=2)
Thu 04/21/2016 09:13:16 PM : [ZW-SHOW         ]    Associations for group 001 of ZW009_1 House Energy Meter Battery
Thu 04/21/2016 09:13:16 PM : [ZW-SHOW         ]       - Node   1 - [This ISY]
Thu 04/21/2016 09:13:16 PM : [ZW-SHOW         ]       - Node   2 - Siren
Thu 04/21/2016 09:13:16 PM : [ZW-SHOW         ]       - Node   4 - Landons Room Smoke Alarm
Thu 04/21/2016 09:13:16 PM : [ZW-SHOW         ]       - Node 219
Thu 04/21/2016 09:13:16 PM : [ZW-SHOW         ]       - Node 233
Thu 04/21/2016 09:13:16 PM : [ZW-SHOW         ] ----------------------------------------------
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ] ----------------------------------------------
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ] ZW008_1 uid=8 type=4.161.0 mid=312 tid=1 pid=1 model=7
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ]    -  x20  V0  BASIC
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ]    -  x80  V0  BATTERY
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ]    -  x70  V1  CONFIGURATION
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ]    -  x85  V1  ASSOCIATION
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ]    -  x71  V1  NOTIFICATION
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ]    -  x72  V1  MANUFACTURER_SPECIFIC
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ]    -  x86  V0  VERSION
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ] Node   8 - Master Bedroom Smoke Alarm has the following neighbors
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ]    -          - Node   1 - [This ISY]
Thu 04/21/2016 09:13:20 PM : [ZW-SHOW         ]    - Repeater - Node   2 - Siren
Thu 04/21/2016 09:13:21 PM : [   ZW009_143]       ST 163270 (uom=73 prec=2)
pic.tiff
Edited by binaryman
