Insteon 2441TH Thermostat not updating data in eKeypad Pro
rjorr1972
I am running eKeypad Pro v2.24.0 (4) interfacing with a UDI isy 994i v4.4.6 - controlling the Insteon 2441 TH.
When I make a change to the temperature on my iPhone, the eKeypad app and thermostat will respond one value change and then the app stops responding to additional temp change inputs.  I have to back out up one menu level and then back down in to the thermostat control on the eKeypad app and then I can make another temperature value change.  But again - it is only one digit change and the locks up.
When I first started using the app and thermostat back on my ISY 99i it worked perfectly fine.  At some point after moving to the ISY 944i - I dont recall when - it stopped working.
Any one else having issues?
  • 2 months later...
This is still an issue, at least when connecting through my.isy.io portal.  I will test with direct connect and see if better.
Using V 3.0.2
ISY 4.5.1.
      37.5k
      375k
