Network module missing
Should be under the configuration tab. If not contact UDI.
That's why I'm posting here, for UDI help :-P
It's not under configuration, manage modules says all up to date, and purchase modules wants me to pay 49.99 for it.
The network module functionality included with 4.4.6 and the Portal does not show as a purchased module. It should automatically show up.
More than likely you have upgraded the ISY, but not cleared your Java cache, so are still using an older GUI.
Can you post your versions from the about dialog?
Edited by MWareman
If you have the Portal configured and as MWareman notes the correct UI you might reboot ISY
Jon...
