Alex control don't update KPL buttons?
Hi guys,
Alexa is working just fine controlling things but I noticed that the KPL buttons turn off when Alexa does it..
Is it because I am getting Alexa to turn on off scenes instead of devices or an I missing something?
YES this KPL buttons are the controllers in those scenes..
Cheers,
Alex
Edited by TheFallenAngel
I'm confused. You title indicates that the KPL button don't respond, but your text says that they do respond. In any case, if you use Alexa to control the scene, then the button should respond, if you use Alexa to control the linked device, then the button won't respond.
Edited by stusviews
I am using Alex to control the scene. And the KPL buttons are not lit after that.. The title doesn't say they don't respond, it says they are not getting updated (their lights).
Cheers,
Alex
What is the result if you turn the scene on and off using the Admin Console?
OK that was weird.. I went to test what you asked and worked perfectly fine just as expected. Right after that I did it with Alexa again and this time it worked fine.. Maybe all I needed to do is once run the scenes via the ISY Console.. I guess this will be a GOOD TO KNOW thing :)
Cheers,
Alex
