Update: 0.9.711
James Peterson
New Update is out.
Fixes for variables getting displayed on multiple profiles form different ISYs
A few sensor fixes
Security fixes during PIN entry and removal
Variable filtering/searching added
Added option for compressed layout for variables in settings
updated a few things due to Google IO announcements for TTL on a few sources that I was using
cleaned up some unused resources to make apk a bit smaller.
a few scene adjustments
bugs fixes... bug fixes...
Update 0.9.712 to fix lollipop crash issue.
James,
Agave is consistently crashing after upgrade. The app will open ok, going to menu, programs crashes app and it closes right away. There is an option to send report, but it looks like it is to Google, not you.
Dennis
Update - Agave is also crashing when selecting Things from the menu.
James,
Dennis
Remind me what you version of android you are running and devices?
James,
Dennis
also, I am not seeing the crash reports..
Do you want me to go ahead and click on Report?
It doesn't look like it goes to your email address.
Crash reports go to the Android Developer console, where the developer can analyse them. You should definitely send them when there is a crash.
Sent from my Nexus 6P using Tapatalk
Yes, do send them.
I guess I my wife "borrowed"(S4)  a phone from a friend.
Yes, do send them.
Crash report sent.
This appears to be an issue with lollipop devices.
I upgraded a few things and it appears that there is an issue with the new gradle.
Downgraded and fixing.   I'll have an update out in about 2 min.  You should see it in abut 30.
Reference:
https://code.google.com/p/android/issues/detail?id=210467
James,
Dennis
Installed the new update this morning and did some quick poking around. This seems to have corrected the issue.
Thanks for the fast fix.
I'm having trouble accessing my thermostat with this update. The app crashes when trying to pull up the thermostat. I have also added it to the home screen and it shows text that says error: device takes or not supported" and then it lists the node address
Sent from my SM-G920V using Tapatalk
Please send me these errors so I can debug them. It is possible that it is a thermostat that I have not got completely working yet.
Sent from my Nexus 5X using Tapatalk
Just sent a crash report. The thermostat is an insteon model that was working in previous versions.
I know where it is failing, just not much information why.  Can you try to do a Data Refresh from the settings page and tell me what happens after that?
nodeInfo>
<node flag="128" nodeDefId="Thermostat">
<address>1E C EF 1</address>
<name>Main HVAC- Main</name>
<parent type="3">28571</parent>
<type>5.11.13.0</type>
<enabled>true</enabled>
<deviceClass>1</deviceClass>
<wattage>1000</wattage>
<dcPeriod>60</dcPeriod>
<pnode>1E C EF 1</pnode>
<ELK_ID>G03</ELK_ID>
<property id="ST" value="146" formatted="73.0°" uom="degrees"/>
<property id="CLIMD" value="11" formatted="11" uom="n/a"/>
<property id="CLISPC" value="146" formatted="73.0°" uom="degrees"/>
<property id="CLISPH" value="102" formatted="51.0°" uom="degrees"/>
<property id="CLIHUM" value="45" formatted="45%" uom="%"/>
</node>
<properties>
<property id="CLIFS" value="7" formatted="Auto" uom="n/a"/>
<property id="CLIHCS" value="2" formatted="Cooling" uom="n/a"/>
</properties>
</nodeInfo>
nodeInfo>
</node>
<properties>
</properties>
</nodeInfo>
OK.  I see the issue as it pertains to Agave.
now to fix it.
What mode is your thermostat in?  I am only aware of 8 separate states that an insteon thermostat can be in.  I see that yours is set to "11" .  I need to get information on this to fix it.
Did you recently change the mode on your thermostat?
Weird thing, i just logged into the console and it said the mode was "11" which i have never seen before. I toggled it to heat and then back to off and agave is back to the way it should be. Appreciate your help and sorry for your troubles.
No problem I added a catch that will not crash the app when this happens again. Thank you for posting it.
      37.5k
      375.5k
