ISY Fires Random Device not in Scene
jwagner010
I have a scene (Downstairs - Entry - Vent-30 [7409]) with the 30 minute button of a Countdown Timer (0F.50.98) in it and also a Secondary Button on a KPL (3B.91.A9) in another room in the scene.  All works fine when I press the KPL or the 30 minute button on the Countdown Timer.  My problem is when I trigger the scene from the ISY admin console main screen or using an ISY program it not only executes this scene but turns on a switchlinc dimmer (3D.AC.3D) not defined in the scene.  I tried removing the 3D.AC.3D Switchlinc Dimmer manually from the scene on both the KPL and Countdown Timer but still when I trigger this scene from the ISY it turns on or off the 3D.AC.3D device.  I have also attached a Test Scene below but have no idea on how to understand it.  Any help appreciated.
Mon 05/30/2016 10:59:20 AM : [GRP-RX      ] 02 61 1E 13 00 06
Mon 05/30/2016 10:59:20 AM : [iNST-SRX    ] 02 50 3D.AC.3D 3D.C7.22 65 13 1E    LTOFFRR(1E)
Mon 05/30/2016 10:59:20 AM : [std-Cleanup Ack] 3D.AC.3D-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 05/30/2016 10:59:20 AM : [iNST-SRX    ] 02 50 0F.50.98 3D.C7.22 61 13 1E    LTOFFRR(1E)
Mon 05/30/2016 10:59:20 AM : [std-Cleanup Ack] 0F.50.98-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Mon 05/30/2016 10:59:21 AM : [CLEAN-UP-RPT] 02 58 06
Mon 05/30/2016 10:59:21 AM : [iNST-SRX    ] 02 50 3B.91.A9 3D.C7.22 61 13 1E    LTOFFRR(1E)
Mon 05/30/2016 10:59:21 AM : [std-Cleanup Ack] 3B.91.A9-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
<html><font color="red">----- Downstairs - Entry - Vent-30 Test Results -----</font></html>
<html><font color="red">[succeeded]</font> Downstairs - Vent - E -30min (F 50 98 5)</html>
<html><font color="red">[succeeded]</font> Downstairs - Entry - Vent (3B 91 A9 6)</html>
Device 3D.AC.3D has a link record with the Scene number.   Look at the link records in 3D.AC.3D as it responded to the Scene Off even though not in the Scene definition that the ISY is aware of.
Select the device with ID 3D.AC.3D. The column at the far right will indicate any scene that the device is a member of.
Thats the weird thing if I select the device 3D.AC.3D the right column does not show it being a member of a scene with either the KPL Secondary button or the 30 minute button on the coundown timer.
How do I remove this scene from 3D.AC.3D?
Edited by jwagner010
What does the Downstairs - Entry - Vent-30 scene have as responders? Did you try Restore Device followed by Write Updates to Device?
In my first post I show a screen shot of the Downstairs - Entry - Vent -30 scene and its responders.  It doesn't have 3D.AC.3D.  So using the ISY admin console I added 3D.AC.3D to the scene, then deleted 3D.AC.3D from the scene which appears to have fixed the problem for now.  I will monitor. Something was out of whack, just not sure what it was.
It's gremlincs again. They always travel in pairs so they're called dual band gremlincs B)
      378.5k
