June 1, 20169 yr I'm a pretty deep technical guy, but a completely newbie to the home automation world, so thanks for bearing with me! I have a fairly recently installed 2GIG security system setup with the CP21 control panel and TS1 (touch panel) with the 2GIG passive RF sensors for door and windows throughout my house. I have the ISY994iZwPRO/IR that I'd like to make the primary programmable controller for my system and begin to expand for adding some more active components. If I'm thinking correctly, the 2GIG sensors are RF-only and are NOT Z-Wave, which means they would NOT be accessible via the ISY -- this would mean my only option for recognizing an open window / door would be to trigger a scene from the 2GIG somehow and pass that through to the ISY. So, two questions: 1) How should the 2GIG CP21 and the ISY994 show to each other? Are they both ZWave devices? Are they both controllers? Should I be adding one as the primary? I know there may be more than one right answer, so I need someone to tell me the the MOST right answer, since I don't know where to start.... 2) If I want to programmatically recognize when a door/window is open/closed, what is my best option for moving forward? Recommendations? Thanks everyone!
June 1, 20169 yr Is this what you're doing? http://forum.universal-devices.com/topic/14842-connecting-to-2gig-controller/
June 1, 20169 yr Author Yes, I think so, but there really isn't an answer to that question either -- the documentation for how to handle the controller "handoff" is pretty weak IMO. I tried both directions without any clear success. The 2GIG would switch to Secondary, but I'm not clear what that really means in the grand context of things. I'd love some direction on where to get a good primer...
June 1, 20169 yr I've never tried it, so I'm not of much help. (This z-wave forum seems to get less traffic than some of the others. I wonder if you'd get more responses asking a general question about primary/secondary setups.) Edited June 1, 20169 yr by kohai
January 11, 20179 yr Yes, I think so, but there really isn't an answer to that question either -- the documentation for how to handle the controller "handoff" is pretty weak IMO. I tried both directions without any clear success. The 2GIG would switch to Secondary, but I'm not clear what that really means in the grand context of things. I'd love some direction on where to get a good primer... Did you ever figure this out? Our monitoring company just installed a 2GIG CP21 to replace our older unit since they're phasing out 2G communications.
February 26, 20179 yr I posted the referred to topic in 2014. Still have no solution. Like aegixx, I'd like to have the 2GIG panel be able to pass state information about the RF devices connected to 2GIG. I can get the ISY and 2GIG controllers to 'see' each other, and can play with which one is primary, secondary, etc. --but I'm not sure how to make this useful. Ideas on how to figure out? thanks
February 26, 20179 yr Hi breischaft, You may need to make 2GiG secondary controller and ISY Primary. Have you followed the instructions here? http://wiki.universal-devices.com/index.php?title=ISY_Z-Wave_GenII_-_Instructions#Shift_Primary_Control_to_ISY With kind regards, Michel
February 26, 20179 yr Yes I have. The 2GIG is secondary. I see it in the tree. But there are no options to see the RF devices that are connected to the 2GIG. This is where I would like to understand what the Z-wave configuration parameters are and can do for me. Can the ISY read states of the devices connected to the 2GIG? ideally, I will be able to tap into the door contacts and other security devices that are connected to the 2GIG and be able to use them for programs in the ISY. thanks for your reply.
February 27, 20179 yr Hi breischaft, I am not sure I understand the relationship between configuration parameters and your devices. From what I gather, the only thing you are seeing is a node for the other controller BUT not all the devices attached to it. If this is correct, then it seems a step was missed (import existing network): http://wiki.universal-devices.com/index.php?title=ISY_Z-Wave_GenII_-_Instructions#Importing_an_Existing_Z-Wave_Network With kind regards, Michel
February 28, 20179 yr The devices attached to the other controller are not Zwave, they are RF. I was hoping to somehow pass their state information from the other controller to the ISY. This is where the only thing I can see on the ISY are the configuration parameters, which I know nothing about. Since it looks like the ISY can 'read' these parameters from the other controller, I didn't know if there was an opportunity to use these to communicate. thanks
February 28, 20179 yr Hi breischaft, Unfortunately that's not possible without tight integration/development. With knid regards, Michel
