June 3, 201610 yr It looks like according to Wink they are about to tell if a door lock slot has a code in it. https://twitter.com/TheWinkApp/status/738009304398077954 Can anyone help me with discovering this request in the api. I don't need the code, I just want to be able to check it a slot has a code so I don't overwrite it.
June 4, 201610 yr I would love to see this capability. I hate having to write down what lots I have put what codes into.
June 4, 201610 yr Author If this is not possible with the ISY, they need to add it, like now. Can't let features like this slip through the cracks.
June 5, 201610 yr The Leviton vrc0p+3 lets you get a user code report with actual user codes along with the status (vacant/occupied) through their own simplified serial API which is built is on top of the zensys serial API: User Code: Get User Code: >NxSS99,2,UserID X = lock node ID User ID = 1 to max. supported User Code report: <nx,99,3,UserID,status,code1,code2….,codey Status = 0 (available), 1 (occupied), 2 (reserved), 3(not available) Code = 4 to 10 digit ascii number http://www.electrical-help.com/thread/2057 OpenZwave implements COMMAND_CLASS_USER_CODE, so it can probably be done from there too. Since Universal Devices must have access to the zensys serial API, I guess they could implement it as well. Edited June 5, 201610 yr by vjk
June 5, 201610 yr I never write down codes. I almost never write anything down I do keep track of who is in each slot using a spreadsheet, but even 'notepad' will do.
June 14, 20169 yr I use the note feature in the device itself to write what code goes to reach user. This helps me keep track
June 14, 20169 yr Author While all of these options are acceptable for average use. I am working on app usage setting and clearing codes. I could care less what the code is. I just want the app to be able to tell if a code exists in a program slot so it doesn't overwrite codes that already exist.Sent from my Nexus 5X using Tapatalk Edited June 14, 20169 yr by James Peterson
June 14, 20169 yr Use the suggested method(s) indicating a name instead of a code. You may not be able to get the lock to do something it's not capable of.
June 14, 20169 yr Author Please see first post. Wink claims to be able to do exactly what I am asking. I called and talked to their customer service to verify and they can query the lock to determine if a code exists in a slot from the Schlage locks. So far this is not possible via the ISY as far as I know so I want to ensure that this gets in for new updates.
June 14, 20169 yr Some Schlage locks do have some ISY access to user codes, others do not. Which lock do you have in mind?
June 14, 20169 yr Author Some Schlage locks do have some ISY access to user codes, others do not. Which lock do you have in mind? Any or all. Point me towards the API calls for retrieving this information.
June 14, 20169 yr I emphasized some access, for example, which user operated a BE469. Does Wink have access to, in particular, the Schlage FE599 user codes? Or BE369?
June 14, 20169 yr Author For me it doesn't matter. I am just adding the ability to my app and I want to include all possibilities for capable locks. So if there is a way to query codes on any locks, I'd like to know which ones and what the API request are for them. So does anyone have this?
