Initiate device add/delete from API
James Peterson
Adding the ability to initiate a device add or device removal from the API would be invaluable.  For app developers like myself, I feel the ability to add advice to the ISY from an app would greatly improve the user attraction as well and usability of our apps and programs.  I don't know where UDI is on something like this, but I feel it should be on the tippy top of priorities if the ISY is going to compete with other platforms.
I agree with this.
I add devices all the time with MobiLinc so it must be possible.
What type of devices? I am only aware of X10.
Sent from my Nexus 5X using Tapatalk
I add all kinds of insteon devices. I'm on iOS though. Every time I add a switch or such I just add it directly via MobiLinc as opposed to writing the address down and adding it later.
It's probably done thru the SOAP API. James, I think you are using REST, which dosnt support this yet. REST does allow for including zwave devices though.
I know Michel has previously indicated their plan to migrate as many SOAP interfaces to REST as possible.
Michael.
Mildly confused.  I do not recognize those address formats other then for ELK.  Can you put in a standard Insteon address?  12 AB CD
Yeah.  Not sure about the text in the field but I always do the 12.34.ab address format and it works great.
Michael.
My app can do either or depending on what is needed.  I just find REST a "LOT" simpler then SOAP.  If there are calls that will allow this, then I need help finding them, because I have looked through the docs many times.
OK,  I'll look into it.  Thanks for the info.
I'm pretty sure 'AddNode' is what your after... Takes an ID, Name and Type. I haven't looked into trying it though - but it's listed on the Wiki page about the SOAP API.
I just got a rely from Michel K.  It does appear to be available in SOAP.  I'll see what I can do with it.  Really wish this was REST.
thx
thx
I really wish I had your skills in Android development. But work with what we have. (Smile)
You're doing a great job and many of us understand the pain you feel. You've come so long way in a short period of time.
My sincere thanks and blessings.
Gary
Sent from my Nexus 6P using Tapatalk
