How do I make a conditional program work?
Hi Eug,
Yes, that's clear: controlling devices and adding to ISY does NOT require links in the PLM since they are all direct commands. Getting statuses from devices OR controlling scenes requires links in the PLM. If the PLM has no links regardless of what you do, then there's an issue with the PLM.
I can add devices to the PLM without issue, and the ISY has no problem controlling devices, or querying them.
Just want to make sure that's clear in case it changes your hypothesis, before I call SmartHome to RMA the PLM.
Ok, a new PLM is on its way to me from Smarthome. When I get it, do I just do a "restore PLM", or is there more to it than that?
Replacing the PLM fixed the problem. Thanks!
