James Peterson Posted June 29, 2016 Posted June 29, 2016 Pushed a new patch update. This update: adds some fixes for the thermostat status adds fan state hvac current state of cooling and heating This patch will also fix a few other status change problems that would not register right away. fixed an issue with humidity not registering correctly. fixed an issue with device properties not registering correctly on some zwave devices. (could not test, but hopeful fix for Celsius in thermostats) as always post issues and bugs. thanks to all that helped with that round.
G W Posted July 1, 2016 Posted July 1, 2016 James, Did you see the PM I sent you about ELK support? Best regards, Gary Funk
James Peterson Posted July 1, 2016 Author Posted July 1, 2016 Yes. I am kinda on the fence about that. What if I set the alarm off accidentally and I can't turn it off? Sent from my Nexus 5X using Tapatalk
arw01 Posted July 2, 2016 Posted July 2, 2016 give an option to require a pin code to arm dis-arm the alarm, then the user has the responsibility to decide if it's a big deal to them or not.
G W Posted July 2, 2016 Posted July 2, 2016 Yes. I am kinda on the fence about that. What if I set the alarm off accidentally and I can't turn it off? Sent from my Nexus 5X using Tapatalk The alarm system will not be active. Best regards, Gary Funk
