Console Java woes
It seems UDI's dependence on Java has become a bit of an albatross. With the latest updates of Java and Chrome, I am unable to access the console.
I know this topic has been addressed here many times over the past few years, but the answers don't seem to solve the problem.
I've seen suggestions to update the firmware, but I have no way to do that - Catch 22!
I am able to access the web interface (after messing around with java settings to allow it) but not the console. It claims I need to update Java, but I already have the latest version (version 8, update 91)
BTW, since I've recently moved it's fine if I have to do a reset of my device to install new firmware - but I need to know how to do it!
Already set my device address in the exceptions list.
I downloaded the admin console. When I open it I get:
Application Block by Java Security
For security, applications must now meet the requirements for the High or Very High security settings, or be part of the Exception Site List, to be allowed to run.
  [More Information]
Reason: Your security settings have blocked an application signed with an expired or not-yet-valid certificate from running.
My Java security setting is set to High (not Very High). There are no other choices.
Particulars:
isy994i
OSX El Capitan 10.11.5
Chrome/Safari but willing to use any browser that will work
Edited by jtara92101
My Java security setting is set to High. The only other setting available is Very High.
Now works. I had to download the Admin Console directly from the UDI website. Using the link on the device interface gives me a version of the Admin Console that won't work with current Java security.
This isn't installing for me. I get an application error "Unable to launch application"
Since Java seems to be going the way of the dodo bird and browsers are dropping support, what is the UD's plan for the future of Java's use in the administration of the ISY devices?
Yes, but what about the fact that many applications are no longer being written in Java and/or being converted to other platforms, like HTML5?
And what about the rumors that even Oracle is losing interesting in continuing its support for Java?
  • 10 months later...
I have an ISY at a remote location.  How do I open the admin console when Java Application Blocked. It says "expired or not-yet-valid certificate".  For instance to get to the remote site i use: http://cabb15.mine.sample/WEB/udajax.htm . I have tried http://isy.universal...994i/admin.jnlp  but that brings up the local instance, not the remote location?
Edited by fastbird1
  • 2 months later...
I'm no sure if this is the right spot, but I could not find a separate discussion about the desktop icon.
Is there a higher resolution version of the admin console icon available could use? The console is the only lowers/blocky icon on my Dock, and it really sticks out.
Edited by stevesreed
