Cannot add Insteon Thermostat
Hello.
I cannot add my Insteon Thermostat.
I finished adding every single Insteon Device that I have, and I bought the ISY994i so I can program the thermostat based on all the devices.
Failed to add device, Reason 10
Insteon Thermostat 2441TH
For some reason it detects as Energy Management.
Even when I select the model manually, it fails.
Tried Start Linking and adding Manually
What is your firmware version? What is the UI version?
I have no suggestion other than updating both the firmware an UI to 4.5
The thermostat was working before what?
Try another factory reset on the stat.
I did this many times on my 2441ZTH units before they connected.. My newer firmware unit never did connect properly on older firmware versions I haven't tried it since v5, though.
